Alphacool Apex Thermal Pad Soft 16W/mk 100x100x1mm
- Article no.: 13492
- EAN: 4250197134927
- Weight: 0,051 kg
- Available: There are more than 5 units available
Powerful!
Increased lifespan!
Versatile!
Technical data thermal pad | |
Dimensions (L x W x H) | 100 x 100 x 1mm |
Thermal Conductivity (ASTM D5470) | 16.6 W/mK (±10%) |
Hardness (ASTM D2240) | 65 (Shore 00) (±5) |
Working temperature | -50 to ~150°C |
Volume Resistance (ASTM D257) | 5×10¹² Ohm-m |
Dielectric Breakdown Voltage (ASTM D149) | 5 KV/mm (±10%) |
Density (ASTM D792) | 3.6 g/cm³ (±10%) |
Elongation (ASTM D412) | 20% |
Weight Loss (ASTM E595) | less than 1% |
Flame Rating (UL 94) | V-0 |
Color | dark grey |
Dicke: | 1,0mm |
Flächenmaße: | 100 x 100mm |
Wärmeleitwert: | 16W/mk |
![WAGZ Alphacool Wärmeleitpad für NexXxoS GPX 3W/mk 15x15x1,5mm red marked PE Bag (24 Stück)](https://aquatuning.shop-cdn.com/media/image/8e/b3/ac/1010964_11H1o4tWLIuVqd_200x200..jpg)
![WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 100x100x0,5mm](https://aquatuning.shop-cdn.com/media/image/b1/1c/62/1023425_17w0umbstXrrt5_200x200..jpg)
![WAGZ Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 100x100x1mm](https://aquatuning.shop-cdn.com/media/image/79/e3/e3/1021762_1S5OcLc7FHcQLl_200x200..jpg)
![WAGZ Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 100x100x0,5mm](https://aquatuning.shop-cdn.com/media/image/e3/b9/82/1021761_1MSYNnkNGqo0Yk_200x200..jpg)
