Alphacool Eisschicht thermal pad - 17W/mK 100x100x1mm
- Article no.: 12465
- EAN: 4250197124652
- Weight: 0,051 kg
- Available:
Alphacool’s ultimate solution to cool your computer with a layer of ice. Not frozen water but a sensational new thermal pad:
With up to 17 W / mk pads surpass all previously-seen thermal pads and pastes. So now practically all hardware components can be easily and cleanly covered with ice!
The "Alphacool Eisschicht" offers all the benefits and features of a typical thermal pads: self-adhesive, elastic, adaptable, and more! It canbe used in many applications: RAM and motherboard coolers or graphics cards and CPU coolers, wherever board meets heatsink you are well advised with the Alphacool Eisschicht.
The pads are available in different power levels, 11, 14 and 17W / mk each available in 0.5mm, 1mm and 1.5mm thickness to be able to compensate for differences in height perfectly. Likewise, any thickness is again available in 100x100mm and 120x20mm (suitable for RAM cooler). These can be easily cut with scissors to separate the right size for each component to be individually configured.
Dicke: | 1,0mm |
Befestigung: | leicht haftend |
Flächenmaße: | 100 x 100mm |
Wärmeleitwert: | 17W/mk |
![WAGZ Alphacool Wärmeleitpad für NexXxoS GPX 3W/mk 15x15x1,5mm red marked PE Bag (24 Stück)](https://aquatuning.shop-cdn.com/media/image/8e/b3/ac/1010964_11H1o4tWLIuVqd_200x200..jpg)
![WAGZ Alphacool Eisschicht Wärmeleitpad - 17W/mK 100x100x0,5mm](https://aquatuning.shop-cdn.com/media/image/0a/f7/e2/1011307_1u58SmM7StKuZz_200x200..jpg)
![WÄM Alphacool Core Wärmeleitpad Soft 9W/mk 100x100x3mm](https://aquatuning.shop-cdn.com/media/image/5e/20/1c/1023203_1hkSFs7gTTyZwb_200x200..jpg)
![WAGZ Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x2mm](https://aquatuning.shop-cdn.com/media/image/d8/51/2b/1021764_1XgMtctl9TqwUd_200x200..jpg)
![WAGZ Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x3mm](https://aquatuning.shop-cdn.com/media/image/32/00/5e/1021763_1PFyMpyHDB5PBY_200x200..jpg)
![ROH Alphacool Eisbaer TPV Extension Set (Schlauch und Anschlüsse)](https://aquatuning.shop-cdn.com/media/image/c2/dc/f8/1019315_1k5WuKavuqDVz8_200x200..jpg)
![ANS Alphacool HF Anschraubtülle TPV Metall - 12,7/7,6mm Gerade - Black - 6er Kit](https://aquatuning.shop-cdn.com/media/image/54/43/08/1016782_1_200x200..jpg)
