Alphacool Eisfach - Single Laing DDC - backside modification kit
- Article no.: 15307
- EAN: 4250197153072
- Weight: 0,118 kg
You have the Alphacool Eisfach in the DC-LT or D5 version and would like to switch to the DDC version? With this modification kit, no problem. Knowing Alphacool, any kind of modifying, expanding and upgrading is no problem, as always.
Just remove the back of the Eisfach and attach the new DDC back. And just like that, you have a system with the power of the DDC pump.
On the back:
On the right side of the back are two display spaces for 5mm LEDs, behind the window panel. This lets you create a unique look and illumination. On the left side there are two openings for filling or draining fluid. The final two 1/4” threads are meant for the inlet and outlet. Behind the inlet, a Bubble Down unit has been installed to prevent turbulence which could let air into the water circulation.
Scope of Delivery:
- 1x Alphacool Eisfach - Single Laing DDC - backside modification kit
