Lighting modules
Close filters
SZ Alphacool Aurora HardTube LED Ring 13mm Deep Black - RGB Alphacool Aurora HardTube LED Ring 13mm Deep Black - RGB
The Alphacool Aurora RGB LED HardTube Ring is a perfect solution for illuminating HardTubes. The Aurora RGB LED rings are simply pushed over the HardTubes. This unique solution offers a wide range of options for customizing your own...
SZ Alphacool Aurora HardTube LED Ring 16mm Deep Black - RGB PHT EOL Alphacool Aurora HardTube LED Ring 16mm Deep Black - RGB
60%
WACZ Alphacool Aurora XPX RGB Frame - Black PHT EOL Alphacool Aurora XPX RGB Frame - Black
Highlights very easy assembly 15 RGB LEDs for perfect lighting Compatible with all standard RGB controllers For the Eisblock XPX satin or clear CPU cooler The Alphacool Aurora XPX RGB Frame is designed for anyone who wants to perfectly...
€3.99 * €9.95 *
60%
WACZ Alphacool Aurora XPX RGB Frame - Chrome PHT EOL Alphacool Aurora XPX RGB Frame - Chrome
A perfectly illuminated CPU water cooler is a real eye-catcher in every water-cooled gaming PC. The Alphacool Aurora XPX RGB Frame is the perfect solution for lighting the Eisblock XPX Plexi clear or satin CPU water cooler. The RGB frame...
€3.99 * €9.95 *
SZ Alphacool Aurora HardTube LED Ring 16mm Chrome - RGB Alphacool Aurora HardTube LED Ring 16mm Chrome - RGB
The Alphacool Aurora HardTube RGB LED Ring is the perfect solution for illuminating the HardTubes or hoses of the water cooling system. To do this, the Aurora HardTube RGB LED Ring simply has to be pushed over the hose or the HardTube....
€8.48 *
AGZ Alphacool Aurora LED Ring 60mm - Digital RGB Alphacool Aurora LED Ring 60mm - Digital RGB
The new Aurora expansion tank LED rings with addressable RGB connection offer you the best modding options to control and stage your system like a professional. Optics at its finest The new aRGB technology gives you the option to...
€24.48 *
SZ Alphacool Aurora HardTube LED Ring 13mm Deep Black - Digital RGB Alphacool Aurora HardTube LED Ring 13mm Deep Black - Digital RGB
The new Aurora HardTube LED rings with addressable RGB connection offer you the best modding options to control and stage your system like a pro. Optics at its finest The new aRGB technology gives you the option to illuminate your entire...
€10.98 *
SZ Alphacool Aurora HardTube LED Ring 16mm Chrome - Digital RGB EOL Alphacool Aurora HardTube LED Ring 16mm Chrome - Digital RGB
€10.98 *
SZ Alphacool Aurora HardTube LED Ring 16mm Deep Black - Digital RGB Alphacool Aurora HardTube LED Ring 16mm Deep Black - Digital RGB
€11.98 *
WACZ Alphacool Aurora XPX Digital RGB Frame - Black EOL Alphacool Aurora XPX Digital RGB Frame - Black
It's finally here! The new Alphacool Aurora XPX Frame with addressable RGB. Perfect for your XPX CPU cooler. Optics at its finest The new XPX Frame with aRGB technology has additional color options to illuminate your entire system...
€6.99 *
WACZ Alphacool Aurora XPX Digital RGB Frame - Chrome EOL Alphacool Aurora XPX Digital RGB Frame - Chrome
€6.99 *
44%
AGZ Alphacool Eisball Digital RGB - Ring inkl. LED - Ersatzteil Alphacool Eisball Digital RGB - Ring incl. LED - Spare part
Replacement ring Digital RGB LED ring for the Alphacool Eisball expansion tank. The Digital RGB LED ring is simply put over the Alphacool Eisball expansion tank and connected as usual via the 3-pin JST connector.
€9.98 * €17.98 *
