Alphacool Core Geforce RTX 4090 Reference Design with Backplate
- Article no.: WAK
- EAN: 4250197133944
- Weight: 2 kg
Important note: The RTX 4090 Core Reference cooler is not compatible with Nvidia's Geforce RTX 4090 Founders Edition. The RTX 4090 FE is compatible with the following cooler: Alphacool Core Geforce RTX 4090 Founders Edition with Backplate (Art. 13470).
Attention: Please note that a part of the PCB is not covered from the water block
Attention: Unfortunately Inno3D is using two different PCB Layouts. Please check your serial number. If it looks like following, it is not compatible with our water blocks: 32-879-xxxx8xxxx
_________________________________
- Inno3D GeForce RTX 4090 iCHILL Black, 24GB GDDR6X (C4090-246XX-18330005)
- Inno3D GeForce RTX 4090 iCHILL Frostbite, 24GB GDDR6X (C4090-246XX-1833FB)
- Inno3D GeForce RTX 4090 iCHILL X3, 24GB GDDR6X (C40903-246XX-1833VA47)
- Inno3D GeForce RTX 4090 X3 OC, 24GB GDDR6X (N40903-246XX-18332989)
- KFA² GeForce RTX 4090 SG (1-Click OC), 24GB GDDR6X (49NXM5MD6DSK)
- PNY GeForce RTX 4090 XLR8 Gaming Verto Epic-X RGB Overclocked Triple Fan, 24GB GDDR6X (VCG409024TFXXPB1-O)
- PNY GeForce RTX 4090 XLR8 Gaming Verto Epic-X RGB Triple Fan, 24GB GDDR6X (VCG409024TFXXPB1)
Technical data cooler | |
L x W x H | 222,36 x 145,85 x 32,65mm |
Threads | 4 x G1/4" |
Thickness cooler bottom | 11,3mm |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 12 |
Technical data backplate | |
L x W x H | 222,36 x 122,85 x 5,78mm |
Material | aluminium |
Color | black |
SLI kompatibel: | Ja |
Kühlertyp: | Komplettkühler |
Anschluss: | 4x G1/4" |
Material Deckel: | Acryl |
Abmessungen: | 222,36 x 145,85 x 32,65mm |
Hinweis: | Kompatibel bis 16/13mm gerade, Kompatibel bis 19/13mm gewinkelt |
Hardware Modell: | RTX 4090 |
