Alphacool Eiszapfen 16mm HardTube screw-on nozzle 45° rotatable G1/4 - Deep Black
- Article no.: 17409
- EAN: 4250197174091
- Weight: 0,061 kg
Design: 45° screw-on nozzle 16mm
This connector has a 1/4" thread on one side and is therefore compatible with 95% of all components. The other side is suitable for a 16mm acrylic and brass tube. In the middle, this connector is angled at 45° to avoid complicated hose routes. For maximum flexibility, the side with the thread can be rotated.
- Material: Brass
- Colour: Deep Black
dimension
- Length: 46mm
- Width: 23mm
Scope of delivery
- 1x Alphacool Eiszapfen 16mm HardTube screw-on nozzle 45° rotatable G1/4 for acrylic brass tubes - Deep Black
Here you will find an interactive overview of all Alphacool connectors.
| Hersteller: | Alphacool |
| 2nd page: | 16/10mm (ID 3/8" OD 5/8") |
| Rotatable: | Yes - 360° |
| Color: | schwarz; |
| Thread length: | 5mm |
| Compatibility: | Acrylrohre;Messingrohre; |
| Material: | Messing; |
| Specification: | Shape: 45° angled |
| 1st page: | G1/4" external thread |
