Alphacool Eiswolf 2 AIO - 360mm RTX 4090 Founders Edition with Backplate
  • 14485
  • 4250197144858
  • 5,24 kg
€159.98 * €269.98 * (40.74% Saved)
€62.98*
12948 Alphacool Eisblock XPX Aurora Edge - Acryl Black Digital RGB
€59.98*
ROH Alphacool Eisbaer TPV Extension Set (hose and connections)
€16.98*
11951 Alphacool Aurora vertical GPU mount with riser cable
€79.98*
14466 Alphacool Filling bottle Core 500ml
€5.99*
The Alphacool Eiswolf 2 is the first full cover GPU AIO waterblock from Alphacool. It is based... more
Fullcover Waterblock?
Chrome-plated copper
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- Nvidia GeForce RTX 4090 Founders Edition, 24GB GDDR6X (900-1G136-2530-000)
Technical data radiator
L x W x H395 x 124 x 30 mm (±3 %)
Material cooling fins, chambers & channelsCopper
Material threadsBrass
G 1/4 threads2 x for tubes (+ 1x Fillport G 1/4)
For fan size120 mm
Options for fan assembly3 x one-sided / 6 x both-sided
Technical data cooler and pump
L x W x H205.42 x 156.89 x 47.8 mm
Material cooler bottomChrome plated copper
Material cooler topacrylic
Threads2 x G 1/4
Pump typeDC-LT 2
Pump speed2600 rpm (±10 %)
Head of delivery1 m
Maximum flow rate72 L/h
Voltage6-13.5 V DC
Power consumption3.2 W
MTBF50.000 h
Technical data liquid
Colorclear
Ingredient 1Destilled water (CAS-number 7732-18-5)
Ingredient 2Glysantin (CAS-number 1017-21-1)
Working temperatures-15 °C / +90 °C
Technical data quick fasteners
L x D95 x 27 mm
MaterialNylon
For tube size12.7 / 7.6 mm
ColorBlack
Technical data fittings
L x D straight fitting24 x 18 mm
Quantity straight fittings2x
L x B x H 90° fitting35 x 27 x 17 mm
Quantity 90° fittings2x
Material fittingsBrass
Technical data tube
Length50 cm
Material tubeTPV (EPDM/PP)
ColorMatt black
Tube size12.7 / 7.6 mm
Hardness grade35 Shore A to 50 Shore D
Working temperature-50 to +155 °C
Technical data fan
Speed0-2500 rpm
Static pressure3.17 mmH₂O
Air flow rate119.8 m³/h
BearingsSleeve bearing
Fan connector4-Pin PWM
Connection Digital aRGB3-Pin JST + 3-Pin 5 V
Dimensions120 x 120 x 25 mm
Net weight187 g
Max working temperature60 °C
€34.98 *
33%
€5.99 * €8.98 *
€29.98 *
