Alphacool Core 2 XT 280mm CPU AiO
  • 14711
  • 4250197147118
  • 3,919 kg
€269.98 *
13777 Alphacool Apex Stealth Metal Aurora fan matte black 2600rpm (120x120x25mm)
€24.98*
14755 Alphacool Apex 2 Thermal grease 2g
€9.98*
5100065 Alphacool Apex AM5 Contact Frame
€19.98*
The Alphacool Core 2 XT CPU AIOs expand the Core series with powerful all-in-one liquid cooling... more
The Alphacool Core 2 XT CPU AIOs expand the Core series with powerful all-in-one liquid cooling solutions for CPUs. The CPU water block is based on the proven Core 1 cooling technology from the custom water-cooling segment. A high-quality aluminum housing and subtle aRGB lighting give the water block a modern and compact design.
The Core 2 XT CPU AIO follows a classic layout with a CPU water block and integrated pump, robust and flexible TPV tubing, as well as a radiator and fans. Heat dissipation is handled by a NexXxoS HPE Full Copper radiator. Made entirely of copper, the radiator enables efficient heat transfer and provides the foundation for high cooling performance. The Apex Stealth fans deliver the airflow required through the radiator while also adding visual accents with their aRGB lighting.
Proven technology is also used for the CPU water block. The cooling structure is based on Core 1 technology and ensures efficient heat transfer from the CPU to the cooling loop. The new Core DC-LT 3 pump, operating at up to 3800 rpm, provides the necessary coolant flow. It is integrated directly into the CPU water block and is designed for powerful yet quiet operation. The aluminum housing gives the water block a premium appearance without coming into contact with the coolant. Subtle aRGB lighting completes the look of the CPU water block.
In addition to cooling performance, the Core 2 XT places particular emphasis on serviceability and longevity. To achieve this, it uses components from the traditional DIY water-cooling segment and supports the right-to-repair approach. The AIO can be serviced when required, allowing it to remain flexible and usable over the long term. Compared with fully sealed AIO systems, this provides a clear advantage.
The Core 2 XT is aimed at users looking for a powerful AIO liquid cooler while placing value on high-quality materials, proven cooling technology, and ease of maintenance. With the NexXxoS HPE Full Copper radiator, Core 1 cooling technology, and the Core DC-LT 3 pump, this CPU AIO combines easy handling with many of the features of a traditional custom water-cooling system.
AMD: AM4 / AM5
Intel: LGA 1700 / LGA 1851
Material coolerChrome-plated copper (Cu-HCP)
Material coverAluminium (AlMg0,7Si)
Maximum torque G1/4 thread (in Nm)1,00
Maximum torque M2 thread (in Nm)0,13
Maximum torque M2,5 thread (in Nm)0,27
Maximum torque M3 thread (in Nm)0,48
Maximum torque M4 thread (in Nm)1,12
Maximum operating temperature (in °C)60
Minimum operating temperature (in °C)-20
Maximum tested pressure (in bar)2,00
Recommended working pressure (in bar)0,00 - 1,00
LED quantity and length12 Stk / 145,7 mm
LED voltage (in V DC)5
LED power (in W)3,6
LED current (in A)0,06
Technical data Pump
Rated Voltage (V - DC)12V
Operating Voltage (V - DC)8 - 13.5
Input Current (Filled with water) (A)0.30(Max.0.36)
Input Current (No water) (A)0.06(Max.0.10)
Input Current (When measuring the flow rate) (A)0.40(Max.0.48)
Power (W)3.6(Max.4.32)
Speed (At Zero Water Head) (RPM)3800±10%
Max . Flow Capacity (At Zero Water Head) (ml/Min)2100±10%
Max . Water Head (At Zero Flow Capacity) (m - Water)1.4±10%
Acoustical Noise (dB(A))25(Max.30)
Technical data Fan
Dimensions (L x W x H)140 x 140 x 25mm
Material (Frame)Die-cast zinc
Material (Impeller)Plastic
Weight350g
Speed300~2000±10% rpm
BearingSleeve Bearing
Connection4-Pin PWM
Cable length PWM / aRGB40±8 mm (+ 50cm extension cable)
Start-up Voltage6 V DC
Rated Volt12 V DC
Power Consumption5.28 W (Max)
Air Flow75.12 CFM
Static Air Pressure2.36 mmH2O
Noise Level32.8 dBA
MTBF100,000h
PWM controlYes
Zero RPM controlYes
Tacho SignalYes
Auto-restartYes
aRGBYes
LED type5V aRGB
aRGB connection3-Pin JST
LED quantity12
Technical data Thermal paste
ColorGray
Density (in g/ml)2,6~2,7
Viscosity@ 20°C (in Pa s)130 ~140
Thermal conductivity (in W/m−K)6,7
Thermal impedance (in °C⋅in²/W)0.0006
Weight loss after 96 hours@100°C0,1%
Permittivity @ 106Hz2,3
Volume resistivity (in Ohm.cm)2,0 x 10^13
Dielectric strength (in KV/mm)2,0
Working Temperature (in °C)−20 ~ 130
Technical data Radiator
L x W x H314,5 x 144 x 30mm (+/- 3%)
Quantity of cooling channels16
Material threadsbrass
Threads4x G1/4" IN/OUT & 1x Fill-/Drainport G1/4" (max. 5mm thread length)
Possible fan size140mm
Possible fan assembly2x one-sided / 4x both-sided
Thread size fan mountingM3
Pressure tested0,8 Bar
Fin density18 FPI
Weight601g
Awards & Videos
Safety notes
Warning
  • Harmful if swallowed.
  • Do not eat, drink or smoke when using this product.
  • IF SWALLOWED: Call a POISON CENTER/doctor if you feel unwell.
  • Rinse mouth.
  • Dispose of contents/container according to local/national/international regulations.
  • Rinse gently with water for a few minutes.
  • In case of fire: Do not inhale explosion and fire gases.
  • Bei Unwohlsein ärztlichen Rat einholen/ärztliche Hilfe hinzuziehen.
