Alphacool tube AlphaTube TPV 12,7/7,6 - 4x60cm Straight - Black Retailbox
- Article no.: 10251
- EAN: 4250197102513
- Weight: 0,281 kg
*1The brand new AlphaTube TPV hose impresses with its subtle velvet look and its exceptional durability. TPV is an EPDM rubber that is primarily used in industry. For water cooling, this means that it is much more stable than PVC hoses (such as against acids, bases and external influences) and can also withstand higher temperatures. There are no worries about the hoses warping and the water flow being obstructed. It is only minimally harder. Laying it is just as easy and uncomplicated as with PVC hoses. The Alphacool HF TPV fittings, which are also new, have been specially adapted for the hose and are therefore ideally suited due to their high tensile strength, but of course it is also compatible with normal connections.
The hose is supplied in four straight sections, each 60 cm long. These pre-cut pieces make handling easier and allow for a clean and tidy installation.
| Technical Data | |
| Material | TPV (EPDM / PP) |
| Color | Matte Black |
| Operating temperature | -50 to + 155°C |
| Outer diameter | 12.7 mm |
| Inner diameter | 7.6 mm |
| Hose length | 4x60 cm |
Delivery date: in 2 - 3 weeks
