B-Ware Alphacool NexXxoS ST25 Full Copper 360mm Radiator
- Article no.: 1025477
- EAN: 4049469338817
- Weight: 0,97 kg
This is a B-stock item.
It is a returned product that has already been opened. Minor signs of use may be present. All mounting accessories are included and the item is fully functional.
For further details, please refer to item number 1019153.
Important: The product images shown are for illustration purposes only and may differ from the actual B-stock item.
| Hersteller: | Alphacool |
| Fins per inch: | 15 |
| Housing: | Steel |
| Cooling channels: | Copper |
| Slats: | Copper |
| Fan thread: | M3 |
| Fan size: | 120mm |
| Dimensions (L x W x H): | 393 x 120 x 22,5mm |
| Connection: | 2x G1/4" |
| Number of fans: | 3 |
| Thickness: | 0 - 29mm |
| Pressure tested: | 2 bar |
| Color: | Black |
