B-stock Alphacool Eiszyklon Aurora LUX PRO Digital RGB (120x120x25mm)
- Article no.: 1023692
- EAN: 4049469320966
- Weight: 0,194 kg
- Available: Currently there are 2 available - More is on the way
This is a B-stock item.
This item is a returned product that has already been opened. Minor signs of use may be present. The item is not delivered in its original packaging and comes with incomplete mounting accessories. Otherwise, it is fully functional.
Additional information (original item: 1016504):
You may have already seen the Alphacool Eiszyklon Aurora LUX Pro fan on the Alphacool Eisbaer Aurora series. It offers a wide control range as well as outstanding digital RGB LED lighting. The individually controllable 5V aRGB LEDs paired with the special design of the fan frame create unique effects.
Ingenious Lighting
The frame is equipped with digital addressable 5V RGB LEDs which illuminate the whole frame. The frame is not completely transparent, but the illumination is done through narrow slits in four places. On the upper side there are two rows of these slits. Each narrow frame runs along the inside and outside of the frame. This creates a unique illumination which looks very noble. Thanks to the recessed light diffusers the light is distributed evenly. This means that Individual LEDs are no longer visible.
Wide Control Range and Silent
The fan can be controlled from 800 to 2000 rpm via the 4-pin PWM connector. At 800 rpm the fan is almost silent, but still offers a good airflow rate as well as a high static pressure. Therefore, the fan can also be used very well on radiators for a water cooling system. Thanks to the high airflow, the fan is also ideal for ventilating a case. Decouplers are also found directly on the frame. The soft foam padding reduces the transmission of vibrations to the case. A further plus point for the silent capability of the fan.
Connections?
The fan is controlled via a 4-pin PWM connector. The cable is 50 cm long. This allows the fan to be connected to the mainboard or a special controller without any additional adapter cables or extensions. The digital aRGB LED lighting is controlled via a JST 3-pin connector.
| Technical data | |
| Speed | 800 - 2000 RPM |
| Static pressure | 2,0 mm/H2O |
| Air flow rate | 104,49 m³/h |
| Bearings | Hydraulic |
| Fan connector | 4-Pin PWM |
| Connection Digital aRGB | 3-Pin JST + 3-Pin 5V |
| Quantity Digital aRGB LED | 16 |
| Dimensions | 120 x 120 x 25 mm |
| Net weight | 187 g |
| Hersteller: | Alphacool |
| Rated speed range: | 1500 - 1950 U/min |
| Air conveying area: | 100 - 149 m³/h |
| Air flow rate: | 104,49 m³/h |
| Pressure: | 2,00mm H2O |
| Color Frame: | Black; |
| Rated speed: | 2000 U/min |
| Color Rotor: | Black; |
| Nominal voltage: | 12V DC |
| Size: | 120mm |
| Volume: | 35,6 dB(A) |
| RPM signal transmission: | Yes |
| Volume range: | 30 - 49,9 dB(A) |
| Power connection: | 4-pin; |
| Dimensions: | 120 x 120 x 25mm |
| LED: | RGB; |
| Power consumption: | 2W |
