B-stock Alphacool Eisblock Aurora Acryl RX 7900XTX/XT Toxic with backplate
- Article no.: 1023826
- EAN: 4049469322304
- Weight: 1,86 kg
This is a B-stock item.
This item is a returned product that has already been opened. Minor signs of use may be present. The thermal pads are incomplete and the packaging is damaged. The remaining mounting material is complete, and the item is fully functional.
Additional information (original item: 1023356):
The next generation - the Alphacool Eisblock Aurora water cooler for Radeon RX 7XXX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
The fin structure of this Eisblock cooler generation was developed together with AMD board partners. The fin thickness is 0.4 mm, the distance between the cooling fins is 0.4 mm. This ensures a very good water flow while increasing the cooling surface. The jet plate has a revised inlay that spreads the water pressure better over the fins thus optimizing the heat absorption. The adjusted water inflow gives the water a better angle of inflow.
Chrome-plated copper
Design
The Aurora design of the Radeon RX 7XXX Eisblock generation is visually calmer and simpler. Only one O-ring runs around the entire cooler. The design around the cooling fins and jetplate makes for a cleaner look. The illumination of the digitally addressable RGB LEDs is even better distributed throughout the cooler as a result of the chrome plating. The terminal's design is in line with the classic Aurora design.
Thermal paste & thermal pads
- Sapphire AMD Radeon™ RX 7900 XT Toxic
- Sapphire AMD Radeon™ RX 7900 XTX Toxic
| Technical data cooler | |
| L x W x H | 276,7 x 134,2 x 33,99mm |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 16 |
| L x W x H | 276,7 x 109,7 x 6mm |
| Material | aluminium |
| Color | black |
| Hersteller: | Alphacool |
| Cooler type: | Complete cooler |
| Material base plate: | Copper; |
| Material Lid: | Acrylic; |
| SLI compatible: | Yes |
| Dimensions: | 276,7 x 134,2 x 33,99mm |
| Connection: | 4x G1/4" |
| Hardware manufacturers: | AMD |
| Hardware model: | Radeon RX 7900XT;Radeon RX 7900XTX; |
| Notice: | Compatible up to 16/13mm straight; Compatible up to 19/13mm angled; |
