Alphacool AM4 mounting screws
- Article no.: 12970
- EAN: 4250197129701
- Weight: 0,03 kg
The Alphacool AM4 screw set includes all the necessary components to securely and reliably mount a wide range of Alphacool CPU coolers onto a motherboard with an AMD AM4 socket. It is specifically designed for a simple yet stable installation, ensuring optimal contact between the CPU and the cooler – a key factor for effective heat transfer.
This screw set is compatible with all common Alphacool Eisbaer all-in-one CPU water cooling systems as well as the XPX series of coolers. It is ideal for users looking to upgrade their system, replace individual components, or retrofit their cooling setup.
Compatible to:
Alphacool Eisbaer LT
Alphacool Eisbaer
Alphacool Eisbaer Aurora
Alphacool Eisbaer Pro
Alphacool XPX
Alphacool XPX Pro
Important Note:
The screw set is not compatible with all Alphacool XP³ CPU coolers.
Important: We cannot exclude that some AM4 motherboards are not compatible with the mounting frame. Please print out the following PDF. On it you can see the mounting frame in 1:1 format. You can cut out the frame and put it on your mainboard. Check whether any surrounding components collide with the mounting frame.
CutOut-Template.pdf
Delivery date: in 6 - 7 weeks
