Alphacool Eisschicht Light thermal pad - 7W/mK 14x14x1mm
  • 12922
  • 4250197129220
  • 0,008 kg
€0.48 *
Content: 1.96 cm² (€0.24 * / 1 cm²)
The Ice Layers Light are available in the 7W/mk power level in 0.5mm, 1mm and 1.5mm thicknesses. Perfect for compensating for height differences. Each thickness is also available in 100x100mm and 120x20mm (suitable for RAM coolers). These can be easily separated with scissors to individually adjust the right size for each component
Dimensions (L x W x H)14 x 14 x 1mm
Thermal conductivity7W/mK
Colorpink
Fastening: Slightly adhesive
Thickness: 1,0mm
Surface dimensions: 14 x 14mm
Thermal conductivity: 7,0W/mk
€0.98 *
€1.19 *
63%
€1.58 * €4.28 *
Alphacool Core thermal pad Soft 6.2W/mk 40x40x1mm
Content 16 cm² (€0.31 * / 1 cm²)
€4.97 *
WAGZ Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x2mm
Content 25 cm² (€0.28 * / 1 cm²)
€6.99 *
€6.49 * €8.98 *
WAR Alphacool Eisschicht Light Wärmeleitpad - 7W/mK 120x20x1,5mm PHT EOL
Alphacool Eisschicht Light thermal pad - 7W/mK 120x20x1,5mm
Content 24 cm² (€0.21 * / 1 cm²)
€4.97 *
€1.79 *
