Alphacool Apex Thermal Pad Soft 16W/mk 100x100x0,5mm
  • 13491
  • 4250197134910
  • 0,032 kg
€39.98 *
Content: 100 cm² (€0.40 * / 1 cm²)
€4.28*
€69.98*
13488 Alphacool Apex Thermal Pad Soft 16W/mk 120x20x0,5mm
€14.98*
13493 Alphacool Apex Thermal Pad Soft 16W/mk 100x100x1,5mm
€119.98*
Alphacool offers a wide range of thermal pads for effective heat dissipation of electric... more
Powerful!
Increased lifespan!
Versatile!
Technical data thermal pad
Dimensions (L x W x H)100 x 100 x 0,5mm
Thermal Conductivity (ASTM D5470)16.6 W/mK (±10%)
Hardness (ASTM D2240)65 (Shore 00) (±5)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)5×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)5 KV/mm (±10%)
Density (ASTM D792)3.6 g/cm³ (±10%)
Elongation (ASTM D412)20%
Flame Rating (UL 94)V-0
Colordark grey
WÄM Alphacool Wärmeleitpad für NexXxoS GPX 3W/mk 30x30x3mm yellow marked PE Bag (4 Stück)
Alphacool thermal pad for NexXxoS GPX 3W/mk 30x30x3mm yellow marked PE Bag (4 pieces)
Content 36 cm² (€0.11 * / 1 cm²)
€3.78 *
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück PHT EOL
€21.98 *
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 100x100x1mm
Alphacool Apex Thermal Pad Soft 16W/mk 100x100x1mm
Content 100 cm² (€0.75 * / 1 cm²)
€74.98 *
63%
€1.58 * €4.28 *
€4.38 *
€29.98 *
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x3mm
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 100x100x0,5mm
€3.98 *
