B-stock Alphacool Eisstation DC-LT incl.. Alphacool DC-LT 2600 Silent
PUM B-Ware Alphacool Eisstation DC-LT inkl. Alphacool DC-LT 2600 Silent
  • 1024523
  • 4049469329273
  • 0,392 kg
€19.98 * €42.98 * (53.51% Saved)
This is a B-stock item. This item is a returned product that has already been opened.... more
This item is a returned product that has already been opened. Minor signs of use may be present. Some screws are missing from the mounting material, and the cable sleeve is damaged. Otherwise, the item is fully functional.
For further information, please refer to item 1012973.
Gebrauchte Ware
Color: schwarz;
Fillport: G1/4" internal thread
Material: Acetal;
Connection: G1/4" internal thread
Pump pre-installed: Yes
Number of connections: 4
Pump compatibility: For DC-LT
Container type: Top-mounted container
LED holes: Unavailable
