Sets with pump
Close filters
PUM Alphacool VPP655 - OT12 (G1/2" Außengewinde) PHT EOL Alphacool VPP655 - OT12 (G1/2" external thread)
Alphacool's new power pump series, unique performance at an unbeatable price. The 12V pumps can simply be connected to the power supply and the pump starts up together with the computer! This ensures maximum comfort and the greatest...
€99.98 *
PUM Alphacool VPP655 - T12 (1/2" Schlauchanschluss) PHT EOL Alphacool VPP655 - T12 (1/2" hose connection)
€99.98 *
PUZ Alphacool Laing DDC-SilentBox PHT EOL Alphacool Laing DDC SilentBox
The Alphacool Laing DDC-SilentBox brings absolute silence to your system. With water cooling, if you have decent fans, the pump is usually the loudest. Even if it is whisper quiet, you can still hear it subliminally! Alphacool has...
€7.49 *
57%
PUZ Alphacool Laing DDC-SilentBox Boden EOL Alphacool Laing DDC-SilentBox bottom
Replacement base for the popular Alphacool Laing DDC-SilentBox! You rebuild your system, screw a new cover onto the Laing pump, use different connections and suddenly the foam cutout in the front of the SilentBox no longer looks so nice....
€1.99 * €4.59 *
PUM Alphacool Laing DDC310 - Complete Edition Eisdecke - schwarz/Acetal Alphacool Laing DDC310 - Complete Edition Ice Cover - black/Acetal
Alphacool's new Low Noise Edition of the Laing DDC for absolute silence! The widely used Laing DDC pumps are getting a new addition. Freshly packaged, this pump can start its life with a lot of confidence. A few details have been...
€83.98 *
PUM Alphacool Laing DDC310 - Complete Edition Eisdecke - silber/Acryl Alphacool Laing DDC310 - Complete Edition Ice Cover - silver/acrylic
€83.98 *
PUM Alphacool VPP Apex Pumpe - G1/4 IG inkl. Eisdecke D5 - Acetal V.3 Alphacool VPP Apex Pump - G1/4 inner thread including Eisdecke D5 - Acetal V.3
The Alphacool VPP Apex pump including the Eisdecke D5 Acetal V.3 combines powerful PWM-controlled pump technology with a versatile pump top. Three inlets, two outlets, and a stable mounting base allow for flexible integration into any...
€83.98 *
PUM Alphacool VPP Apex Pumpe - G1/4 IG inkl. Eisdecke D5 - Acryl V.3 Alphacool VPP Apex Pump - G1/4 inner thread including Eisdecke D5 - Acryl V.3
The Alphacool Apex VPP is a powerful pump. Via the 4-pin fan connector, the speed of the pump can be read and controlled via PWM signal. The Apex VPP is supplied with power via the SATA connector. In this version, it is supplied with the...
€83.98 *
PUZ Alphacool Core DDCzero Pumptop mit Pumpe Alphacool Core DDCzero Pumptop with Pump
The Alphacool Core DDCzero Pump Top combines an exceptionally compact design with the powerful Alphacool DDCzero PWM pump. Thanks to its small dimensions, the pump-top combination is ideal for small-form-factor systems and other...
€169.98 *
