Alphacool Powerbutton Body - Deep Black
- Article no.: 17428
- EAN: 4250197174282
- Weight: 0,115 kg
The world-famous water cooling manufacturer Alphacool offers a simple solution with the Powerbutton Body to start your PC quickly and easily. Most computers are positioned under or on the side of the desk. In this position, the start button is usually difficult to reach. In the area of modding, start buttons are also usually positioned differently than usual.
All you need is a vandal-proof switch with a 19 mm thread. The extensive selection of vandal-proof switches gives you the freedom to design your own. You also need a suitable cable that you can connect to the switch and your mainboard. We naturally recommend the Alphacool power button/push button connection cable with a length of 2 or 3 m.
- Dimensions
Diameter base: 50mm
Tower diameter: 45mm
Height: 49mm
Hole for button: 19mm - Material: aluminum
- Colour: Deep Black
Scope of delivery
- 1x Alphacool Power Button Body - Deep Black
- Instructions
