Alphacool Core Geforce RTX 5080 EPIC-X with Backplate
- Article no.: 14740
- EAN: 4250197147408
- Weight: 1,26 kg
- PNY GeForce RTX™ 5070 Ti EPIC-X RGB™ Overclocked Triple Fan Plus (VCG5071T16TFXXPB1-O)
- PNY GeForce RTX™ 5080 ARGB EPIC-X RGB™ Overclocked Triple Fan GPU
- PNY GeForce RTX™ 5080 ARGB EPIC-X RGB™ Triple Fan GPU
- PNY GeForce RTX™ 5080 Overclocked Triple Fan GPU
- PNY GeForce RTX™ 5080 Triple Fan GPU
Technical data cooler | |
Dimensions total (L x W x H) | 180 x 124,10 x 34,07mm |
Material cooler top | Acrylic |
Material terminal | Nylon |
Material Connection thread | Brass |
Pressure tested | 0,8 bar |
Threads | 4 x G1/4" |
Thickness cooler bottom | 3,25mm |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 7 |
Color | transparent |
Technical data backplate | |
Dimensions (L x W x H) | 180,00 x 95,57 x 6,00mm |
Thickness backplate without spacers | 3mm |
Material | Aluminium |
Material base plate: | Copper |
Dimensions: | 180 x 124.10 x 34.07 |
Connection: | 4x G1/4" |
Hardware manufacturers: | NVIDIA |
Hardware model: | RTX 5080; |
Delivery date: in 6 - 7 weeks
