Alphacool Core Geforce RTX 4080 Suprim with backplate
- Article no.: WAK
- EAN: 4250197135320
- Weight: 2,291 kg
- MSI GeForce RTX 4080 16GB Suprim X, 16GB GDDR6X (V511-004R)
- MSI GeForce RTX 4080 Gaming X Trio 16GB, 16GB GDDR6X (V511-005R)
- MSI GeForce RTX 4080 SUPER 16G SUPRIM
- MSI GeForce RTX 4080 SUPER 16G SUPRIM X (V511-248R)
Technical data cooler | |
Dimensions (L x W x H) | 269,16 x 153,70 x 31,64mm |
Threads | 4 x G1/4" |
Thickness cooler bottom | 11,3mm |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 15 |
Color | transparent |
Technical data backplate | |
Dimensions (L x W x H) | 269,16 x 130,70 x 5mm |
Material | aluminium |
Color | black |
SLI kompatibel: | Ja |
Kühlertyp: | Komplettkühler |
Anschluss: | 4x G1/4" |
Material Deckel: | Acryl |
Abmessungen: | 269,16 x 153,70 x 31,64mm |
Hinweis: | Kompatibel bis 16/13mm gerade, Kompatibel bis 19/13mm gewinkelt |
Hardware Modell: | RTX 4080 |
Liefertermin: in 5 - 6 Tagen
