The Alphacool Eisblock XPX Pro 1U is part of the latest generation of CPU water coolers offering you great performance. Optimized flow The Alphacool Eisblock XPX Pro 1U has a large cooling surface area so that the water can flow...
€105.98
The Alphacool Eisblock XPX 1U is the Enterprise Solutions version of the well-known and popular Eisblock XPX CPU water cooler. It has been specially optimized for use in 1U server racks and has extended connection options. This allows...
€79.98
The Alphacool Eisblock XPX Pro 1U Ampere LGA 4926 is a reliable CPU water cooler that offers outstanding cooling performance. Optimized for Ampere LGA 4926 This Alphacool Eisblock XPX Pro is specifically designed for the Ampere LGA 4926...
€125.98
Alphacool ES Mounting Kit EPYC SP5 for AMD Socket LGA 6096. Compatible with Alphacool ES Jet and Stream CPU Coolers. Compatibility: AMD: SP5 (LGA 6096) Technical data Dimensions (L x W x H) 19 x 19,75 x 20mm Material Aluminium Weight per...
€11.98
The Alphacool ES Stream is designed for server and workstation processors on Intel's LGA 4677 socket with large processor cores. Due to the large cooler bottom, the processor is completely covered. The ES Stream is a flow-through cooler,...
€119.99
The Alphacool ES Jet CPU Cooler was specially developed for powerful processors on Intel's socket LGA 4677 in server and workstation systems. With the supplied bracket, the Alphacool ES Jet CPU cooler now also supports the SP5 socket...
€154.98
The Alphacool ES Stream CPU Cooler was specially developed for powerful processors on Intel's socket LGA 4677 in server and workstation systems. With the supplied bracket, the Alphacool ES Stream CPU cooler now also supports the SP5...
€132.98
€154.98
