Mounting sets
Close filters
1 From 2
WACZ Alphacool NexXxoS XP Halter S.754 939 940 AM2 EOL Alphacool NexXxoS XP Holder S.754 939 940 AM2
Individual bracket for AMD 64 CPUs socket 754,939, 940,AM2 (NexXxoS XP or others) with 50mm width and a maximum height of max. 20mm. Allen key is included.
€12.29 *
WACZ Alphacool NexXxoS XP Halter S.1155/1156 EOL Alphacool NexXxoS XP Holder S.1155/1156
This bracket is intended for conversion, extension or as a spare part for the popular Alphacool NexXxos XP (light), X2 up to Plus Highflow. Socket type 1156 Scope of delivery: 1x bracket Note: If you use this holder to replace the old...
€12.29 *
WACZ Alphacool NexXxoS XP³ Schraubensatz - Schwarz Alphacool NexXxoS XP³ screw set - Black
Replacement screw set for the Alphacool NexXxoS XP³ CPU water cooler, but also compatible with other CPU coolers. This mounting set is characterized by its beautiful black color and slim design. Technical data: Knurled nut internal...
€3.98 *
WACZ Alphacool NexXxoS XP³ Ersatzhalterungen - Schwarz PHT EOL Alphacool NexXxoS XP³ Replacement Brackets - Black
AMD and Intel replacement bracket for all Alphacool NexXxoS XP³ CPU coolers. Scope of delivery: 1x Alphacool NexXxoS XP³ replacement brackets - Black
€6.28 *
WACZ Alphacool NexXxoS XP³ Schraubensatz Sockel 2011 4 Stück - Schwarz EOL Alphacool NexXxoS XP³ screw set socket 2011 4 pieces - black
Alphacool NexXxoS XP³ screw set for mounting the XP³ coolers on motherboards with socket 2066, 2011 and 2011-3. Scope of delivery: 1x Alphacool NexXxoS XP³ screw set socket 2011 4 pieces - black
€3.98 *
WACZ Alphacool NexXxoS XP³ Ersatzhalterung für Socket 775,1150,1151,1155,1156,1366,2011,2066 EOL Alphacool NexXxoS XP³ replacement bracket for Socket 775,1150,1151,1155,1156,1366,2011,2066
Now, no one is immune to accidents. Even the most careful users can make a mistake, and how quickly can a scratch or even a crack appear in the acrylic? That's why we have the Alphacool NexXxoS XP³ replacement bracket - black...
€3.88 *
WACZ Alphacool Eisberg AM3 Schaubensatz PHT EOL Alphacool Eisberg AM3 screw set
Replacement AMD screw set for: Alphacool Eisberg 240 CPU - Black Alphacool Eisberg 120 CPU - Black Alphacool Eisberg (Solo) - High Speed Edition 3600rpm - Black Alphacool Eisberg (Solo) - High Speed Edition 2400rpm - Black
Content 4 Stück (€0.37 * / 1 Stück)
€1.48 *
WACZ Alphacool Eisbaer Halterung Sockel 2011-3 narrow ILM PHT EOL Alphacool Eisbaer bracket socket 2011-3 narrow ILM
Alphacool Eisbaer Intel bracket for socket 2011-3 narrow ILM. Suitable for all Eisbaer AIO's and all XPX CPU coolers Scope of delivery 1x Alphacool Eisbaer Intel bracket socket 2011-3 narrow ILM
€5.98 *
WACZ Alphacool NexXxoS XP³ Light Acryl Halterung für Sockel 2011-3 Narrow ILM EOL Alphacool NexXxoS XP³ Light Acrylic Bracket for Socket 2011-3 Narrow ILM
Intel Socket 2011-3 Narrow ILM bracket for all Alphacool NexXxoS XP³ acrylic CPU coolers. Note: The mounting bracket is not compatible with NexXxoS XP³ Acetal coolers! Scope of delivery 1x Alphacool NexXxoS XP³ bracket for Intel Socket...
€5.58 *
67%
WACZ Alphacool NexXxoS XP³ Halterung für Radeon Ryzen S. AM4 PHT EOL Alphacool NexXxoS XP³ bracket for Radeon Ryzen S. AM4
Alphacool NexXxoS XP³ bracket for AMD Ryzen S. AM4 Scope of delivery: 1x Alphacool NexXxoS XP³ bracket for AMD Ryzen S. AM4
€2.98 * €8.98 *
WACZ Alphacool Eisbaer/XPX Halterung für Ryzen S. AM4/AM5 EOL Alphacool Eisbaer/XPX bracket for Ryzen S. AM4/AM5
Alphacool Eisbaer bracket for AMD Ryzen S. AM4 and AM5 Note: The Alphacool bracket for AMD Ryzen S. AM4 and AM5 is compatible with all Eisbaer and XPX CPU coolers. Scope of delivery: 1x Alphacool Eisbaer bracket for AMD Ryzen S. AM4/AM5...
€1.98 *
WACZ Alphacool Eisbaer Socket 775,1150,1151,1155,1156,1366,2011,2066 Halterung mit Backplate und Schrauben Alphacool Eisbaer Socket 775,1150,1151,1155,1156,1366,2011,2066 bracket with backplate and
Alphacool Eisbaer Intel bracket as a spare part. This bracket is the same as the one included in the original box of the Alphacool Eisbaer. Intel 1150/1151/1155/1156, Intel 1366, Intel 2011, Intel 775, Intel 2066, Intel 2011-3, Intel...
WACZ Alphacool Eisbaer Federn und Muttern Alphacool Eisbaer springs and nuts
Replacement kit for all Alphacool Eisbaer. Scope of delivery 1x Alphacool Eisbaer springs and nuts
€4.98 *
WACZ Alphacool Eisbaer Schraubenkit M3 x 5/M3 x 30mm Alphacool Eisbaer screw kit M3 x 5/M3 x 30mm
Replacement screws for the Alphacool Eisbaer. 9x M3 x 30mm for mounting the fans on the radiator. 9x M3 x 5mm for mounting the radiator on the case floor, ceiling or wall. Scope of delivery 1x Alphacool Eisbaer screw kit M3 x 5 / M3 x 30mm
Content 18 Stück (€0.33 * / 1 Stück)
€5.98 *
WACZ Alphacool Threadripper/TR4/TR5/TRX40/SP3/SP6 Halterung für Eisbaer/Eisblock/Silent Loop inkl. Schrauben Alphacool Threadripper/TR4/TR5/TRX40/SP3/SP6 bracket for Eisbaer/Eisblock/Silent Loop incl. S
Mounting bracket for the AMD Threadripper/TR4/TR5/TRX40/SP3/SP6 Compatible with the products Alphacool Eisbaer CPU AIO family Alphacool XPX Eisblock CPU Cooler Be Quiet! Silent Loop CPU AIO family
WACZ Alphacool Eisblock XPX Pro 1U Halterung - LGA 2066/3647 TR4/SP3 Alphacool Eisblock XPX Pro 1U Bracket - LGA 2066/3647 TR4/SP3
Securely mount your Alphacool Eisblock XPX Pro 1U in your system with this bracket. Compatible with Intel LGA 2066, Intel LGA 3647 Narrow and AMD TR4 and AMD SP3. Simply select your bracket and put it together. Technical details Socket...
WACZ Alphacool Eisblock XPX Pro (alle Modelle) und Eisbaer Pro Socket 3647 Square Type Halterung PHT EOL Alphacool Eisblock XPX Pro (all models) and Eisbaer Pro Socket 3647 Square Type Bracket
Securely mount your Alphacool Eisblock XPX Pro 1U or Aurora Edge XPX Pro in your system with this bracket. Technical details Socket compatibility: Intel LGA 3647 Square Type Dimensions Intel LGA 3647: 109 x 79 mm
€11.98 *
WACZ Alphacool AM4 Montage Schrauben Alphacool AM4 Mounting Screws
The Alphacool AM4 screw set includes all the necessary components to securely and reliably mount a wide range of Alphacool CPU coolers onto a motherboard with an AMD AM4 socket. It is specifically designed for a simple yet stable...
€3.98 *
1 From 2
