Alphacool replacement O-rings for Eisblock GPX-N 11964
![WAGZ Alphacool Ersatz O-Ringe für Eisblock GPX-N 11964](https://aquatuning.shop-cdn.com/media/image/4a/4d/e4/1023078_1K7GKJu071wYir_600x600..jpg)
- Article no.: 13375
- EAN: 4250197133753
- Weight: 0,013 kg
- Available:
€3.99 *
Alphacool replacement O-rings for Eisblock GPX and Eiswolf 2. The set contains all O-rings... more
Alphacool replacement O-rings for Eisblock GPX and Eiswolf 2. The set contains all O-rings needed for complete replacement in the following cooler(s) and AIO(s)*:
- item no. 11964, Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 GameRock with Backplate
(* if AIO is available)
61%
![WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 GameRock mit Backplate EOL](https://aquatuning.shop-cdn.com/media/image/d4/13/99/1021613_1fyp4PiQPBG3so_200x200..jpg)
€62.97
€159.97
![ANS Alphacool HF Anschraubtülle TPV - 12,7/7,6mm Gerade - Black - 6er Kit](https://aquatuning.shop-cdn.com/media/image/40/31/87/1016781_1_200x200..jpg)
Alphacool HF compression Fitting TPV - 12,7/7,6mm Straight - Black - 6pcs Kit
Content
6 Stück
(€2.83 * / 1 Stück)
€16.98
![LK Phobya Y-Kabel 4Pin PWM 3x 4Pin PWM - Schwarz 10cm](https://aquatuning.shop-cdn.com/media/image/60/31/72/81138_1AGgNlm7Jmhbvj_200x200..jpg)
Content
10 Zentimeter
(€49.80 * / 100 Zentimeter)
€4.98
