Alphacool fan filter 120mm black
- Article no.: 10297
- EAN: 4250197102971
- Weight: 0,029 kg
€2.98 *
This metal fan filter is a practical solution for protecting the inside of the case from dust.... more
This metal fan filter is a practical solution for protecting the inside of the case from dust. It can be easily attached to a compatible fan and helps reduce the amount of dust entering the case. The coarse metal mesh has only a minimal effect on airflow. When needed, the filter can be cleaned easily and reused afterward.
| Technical Data | |
| Dimensions | 120x120mm |
| Color | Black |
Content
15 Zentimeter
(€13.20 * / 100 Zentimeter)
€1.98
Content
100 Milliliter
(€99.80 * / 1000 Milliliter)
€9.98
