Alphacool fan filter 140mm black
LZ Alphacool Lüfterfilter 140mm schwarz
  • 10298
  • 4250197102988
  • 0,035 kg
€3.38 *
This metal fan filter is a practical solution for protecting the inside of the case from dust.... more
This metal fan filter is a practical solution for protecting the inside of the case from dust. It can be easily attached to a compatible fan and helps reduce the amount of dust entering the case. The coarse metal mesh has only a minimal effect on airflow. When needed, the filter can be cleaned easily and reused afterward.
Technical Data
Dimensions140x140mm
ColorBlack
