Alphacool Core Geforce RTX 5070 GamingPro with Backplate
- Article no.: 14742
- EAN: 4250197147422
- Weight: 1,266 kg
- Palit GeForce RTX™ 5070 GamingPro (NE75070019K9-GB2050A)
- Palit GeForce RTX™ 5070 GamingPro OC (NE75070T19K9-GB2050A)
| Technical data cooler | |
| Dimensions total (L x W x H) | 186,00 x 125,57 x 34,07mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 7 |
| Color | transparent |
| Dimensions (L x W x H) | 186,00 x 97,00 x 6,00mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
