B-stock Alphacool Eiswolf 2 AIO - 360mm RTX 4090 GameRock + Phantom with backplate
- Article no.: 1025381
- EAN: 4049469337858
- Weight: 5,105 kg
This is a B-stock item.
This item is a returned product that has already been opened. Signs of corrosion are present. The mounting material and thermal pads are incomplete; otherwise, the item is functional.
For further information, please refer to item 1023379.
| Hersteller: | Alphacool |
| Radiator dimensions: | 395 x 124 x 30mm |
| Radiator thickness: | 29 - 39mm |
| Radiator size: | 360mm |
| Hose dimensions: | 12,7/7,6mm |
| Base: | Nvidia GeForce; |
| Prefilled: | Yes |
