B-stock Alphacool Eiswolf 2 AIO - 360mm RX 7900XTX Reference with backplate
KOI B-Ware Alphacool Eiswolf 2 AIO - 360mm RX 7900XTX Reference mit Backplate
  • 1024983
  • 4049469333874
  • 5,24 kg
€89.98 * €267.29 * (66.34% Saved)
This is a B-stock item. This item is a returned product that has already been opened.... more
This item is a returned product that has already been opened. Minor signs of use may be present. Deposits are visible inside the cooler, and the 1 mm thermal pads are missing. Otherwise, the item is complete and fully functional.
Additional information (original item: 1023717):
Fullcover Waterblock?
Chrome-plated copper
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- AMD Radeon RX 7900 XTX, 24GB GDDR6
- ASRock Radeon RX 7900 XTX, 24GB GDDR6
- Asus Radeon RX 7900 XTX, RX7900XTX-24G, 24GB GDDR6 (90YV0IT0-U0NM00)
- Biostar Radeon RX 7900 XTX, 24GB GDDR6 (VA7906AEF4)
- Gigabyte Radeon RX 7900 XTX 24G, 24GB GDDR6 (GV-R79XTX-24GC-B)
- PowerColor Radeon RX 7900 XTX, 24GB GDDR6 (RX 7900 XTX 24G)
- XFX Radeon RX 7900 XTX, 24GB GDDR6 (RX-79XMBABF9)
Technical data radiator
Dimensions (L x W x H) 395 x 124 x 30mm (+/- 3%)
Material cooling fins, chambers & channels Copper
Material threads Brass
Material outer housing stainless steel
G 1/4“ threads 2 x for tubes (+ 1x Fillport G1/4“)
For fan size 120 mm
Options for fan assembly 3 x one-sided / 6 x both-sided
Technical data cooler and pump
Dimensions (L x W x H) 268,58 x 144,80 x 47,70 mm
Material cooler bottom Chrome plated copper
Material cooler top acrylic
Threads 2 x G1/4“
Pump type DC-LT 2
Pump speed 2600 rpm (+/- 10%)
Head of delivery 1 m
Maximum flow rate 72 L/h
Voltage 6-13.5V DC
Power consumption 3.2W
MTBF 50.000 h
Technical data liquid
Color clear
Ingredient 1 Destilled water (CAS-number 7732-18-5)
Ingredient 2 Glysantin (CAS-number 1017-21-1)
Working temperatures -15 C° / +90 °C
Technical data quick fasteners
Dimensions (L x D) 95 x 27mm
Material Nylon
For tube size 12,7 / 7,6mm
Color Black
Technical data fittings
L x D straight fitting 24 x 18mm
Quantity straight fittings 2x
L x B x H 90° fitting 35 x 27 x 17mm
Quantity 90° fittings 2x
Material fittings Brass
Technical data tube
Length 50cm
Material tube TPV (EPDM/PP)
Color Matt black
Tube size 12,7 / 7,6mm
Hardness grade 35 Shore-A to 50 Shore-D
Working temperature -50 to +155 °C
Technical data fan
Speed 0 - 2500 RPM
Static pressure 3,17 mm H2O
Air flow rate 119,8 m³/h
Bearings Sleeve bearing
Fan connector 4-Pin PWM
Connection Digital aRGB 3-Pin JST + 3-Pin 5V
Dimensions (L x W x H) 120 x 120 x 25mm
Net weight 187g
Max working temperature 60°C
Gebrauchte Ware
Radiator dimensions: 395 x 124 x 30mm
Radiator thickness: 29 - 39mm
Radiator size: 360mm
Hose dimensions: 12,7/7,6mm
Base: AMD Radeon RX;
Prefilled: Yes
