Alphacool Eisblock XPX CPU replacement cover - silver matte
  • 12697
  • 4250197126977
  • 0,067 kg
€5.09 * €9.79 * (48.01% Saved)
With the XPX Ice Block replacement cover you have the opportunity to customize your XPX Ice... more
With the XPX Ice Block replacement cover you have the opportunity to customize your XPX Ice Block cooler.
In addition to the colored aluminum cover, the package also contains the corresponding Intel and AMD mounting frames and screw caps. Naturally, everything is in the same color as the cover.
  • Dimensions (LxWxH): 65 x 65 x 30mm
  • Connections: 2x G1/4"
  • Pressure tested: 2 bar
  • Color: Silver
  • Housing material: aluminum / acetal
  • Socket: Intel: 1151, 1150, 1155, 1156, 755, 2066, 2011-3, 2011, 1366, 771, 771
  • Socket: AMD: AM4, AM3+, AM3, AM2+, AM2, 939, FM2+, FM2, FM1, G34, 940
Scope of delivery
  • 1x Alphacool Eisblock XPX CPU replacement cover - silver
 Assembly instructions
