B-stock Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 ROG Strix with backplate
KOI B-Ware Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 ROG Strix mit Backplate
  • 1022873
  • 4049469312763
  • 5,24 kg
€119.98 * €269.98 * (55.56% Saved)
This is a B-stock item. This item is a returned product that has already been opened and... more
This item is a returned product that has already been opened and used. Signs of use and water residue are present. The thermal pads and thermal paste are missing, otherwise, the item is fully functional.
Additional information (original item: 1020896):
Fullcover Waterblock?
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- Asus ROG Strix GeForce RTX 3080 OC, ROG-STRIX-RTX3080-O10G-GAMING, 10GB GDDR6X (90YV0FA1-M0NM00)
- Asus ROG Strix GeForce RTX 3080 OC, ROG-STRIX-RTX3080-O12G-GAMING, 12GB GDDR6X (90YV0FAC-M0NM00)
- Asus ROG Strix GeForce RTX 3080, ROG-STRIX-RTX3080-10G-GAMING, 10GB GDDR6X (90YV0FA0-M0NM00)
- Asus ROG Strix GeForce RTX 3080, ROG-STRIX-RTX3080-12G-GAMING, 12GB GDDR6X (90YV0FAD-M0NM00)
- Asus GeForce RTX 3080 Ti STRIX LC Liquid Cooled
- Asus ROG Strix GeForce RTX 3080 Ti Gaming (ROG-STRIX-RTX3080TI-12G-GAMING)
- Asus ROG Strix GeForce RTX 3080 Ti Gaming OC (ROG-STRIX-RTX3080TI-O12G-GAMING)
- Asus ROG Strix GeForce RTX 3090 OC, ROG-STRIX-RTX3090-O24G-GAMING, 24GB GDDR6X (90YV0F93-M0NM00)
- Asus ROG Strix GeForce RTX 3090, ROG-STRIX-RTX3090-24G-GAMING, 24GB GDDR6X (90YV0F90-M0NM00)
Technical data radiator
L x W x H 395 x 124 x 30mm (+/- 3%)
Material cooling fins, chambers & channels Copper
Material threads Brass
Material outer housing stainless steel
G 1/4“ threads 2 x for tubes (+ 1x Fillport G1/4“)
For fan size 120 mm
Possible fan assembly 3 x one-sided / 6 x both-sided
Technical data cooler and pump
L x W x H 162,5 x 266 x 46mm
Material cooler bottom Chrome plated copper
Material cooler top PMMA
Threads 2 x G1/4“
Pump type DC-LT 2
Pump speed 2600 rpm (+/- 10%)
Head of delivery 1 m
Maximum flow rate 72 L/h
Voltage 6-13.5V DC
Power consumption 3.2W
MTBF 50.000 h
Technical data liquid
Color clear
Ingredient 1 Destilled water (CAS-number 7732-18-5)
Ingredient 2 Glysantin (CAS-number 1017-21-1)
Working temperatures -15 C° / +90 °C
Technical data quick fasteners
L x D 95 x 27mm
Material Nylon
For tube size 12,7 / 7,6mm
Color Black
Technical data fittings
L x D straight fitting 24 x 18mm
Quantity straight fittings 2x
L x B x H 90° fitting 35 x 27 x 17mm
Quantity 90° fittings 2x
Material fittings Brass
Technical data tube
Length 50cm
Material tube TPV (EPDM/PP)
Color Matt black
Tube size 12,7 / 7,6mm
Hardness grade 35 Shore-A to 50 Shore-D
Working temperature -50 to +155 °C
Technical data fan
Speed 0 - 2500 RPM
Static pressure 3,17 mm H2O
Air flow rate 119,8 m³/h
Bearings Sleeve bearing
Fan connector 4-Pin PWM
Connection Digital aRGB 3-Pin JST + 3-Pin 5V
Dimensions 120 x 120 x 25mm
Net weight 187g
Max working temperature 60°C
Gebrauchte Ware
Radiator dimensions: 395 x 124 x 30mm
Radiator size: 360mm
Base: Nvidia GeForce;
Prefilled: Yes
