B-stock Alphacool Eisbaer Pro Aurora (Solo) - Digital RGB
WAC B-Ware Alphacool Eisbaer Pro Aurora (Solo) - Digital RGB
  • 1023353
  • 4049469317577
  • 0,906 kg
€39.98 * €84.98 * (52.95% Saved)
This is a B-stock item. This item is a returned product that has already been opened.... more
This item is a returned product that has already been opened. Minor signs of use may be present. The mounting bracket/backplate for socket 1700 as well as the fill port plug are missing; otherwise, the item is complete and fully functional.
For further information, please refer to item 1020273.
Gebrauchte Ware
Base: AMD AM5;AMD AM4;AMD SP3;AMD sTRX4;AMD sWRX8;AMD TR4;AMD TRX40;Intel 2011(-3);Intel 2011(-3) narrow ILM;Intel 2066;Intel LGA 1200;Intel LGA 3647;Intel LGA 1700;Intel LGA 1851;Intel LGA 4189;
Dimensions (L x W x H: 64 x 79 x 54,3mm
Connection: 2x G1/4“ (+ 1x Fillport G1/4”)
Material base plate: Copper
Material Lid: Acrylic;
