Alphacool Core thermal pad Soft 9W/mk 100x100x0.5mm
- Article no.: 13415
- EAN: 4250197134156
- Weight: 0,025 kg
Increased service life!
Versatile use!
Technical data thermal pad | |
Dimensions (L x W x H) | 100 x 100 x 0,5mm |
Thermal Conductivity (ASTM D5470) | 9.0 W/mK (±10%) |
Hardness (ASTM D2240) | 50 (Shore 00) (±15) |
Working temperature | -50 to ~180°C |
Volume Resistance (ASTM D257) | 1×10¹² Ohm-m |
Dielectric Breakdown Voltage (ASTM D149) | ≥8 KV/mm |
Density (ASTM D792) | 3.2 g/cm³ (±10%) |
Elongation (ASTM D412) | 40% |
Weight Loss (ASTM E595) | less than 1% |
Flame Rating (UL 94) | V-0 |
Color | pink |
Fastening: | Slightly adhesive |
Thickness: | 0,5mm |
Surface dimensions: | 100 x 100mm |
Thermal conductivity: | 9,0W/mk |
