Alphacool NexXxoS UT60 Full Copper X-Flow 40mm Dual (2x40mm) Radiator
  • 14298
  • 4250197142984
  • 0,381 kg
€54.98 *
ANS Alphacool Eiszapfen 13/10mm screw-on nozzle 90° rotatable G1/4 - Deep Black
€8.98*
PUM Alphacool DC-LT 3600 - 12V DC - Pump - Industry bulk
€36.98*
It's the best system because it's your system, strive for perfection! The new Alphacool NexXxoS... more
It's the best system because it's your system, strive for perfection! The new Alphacool NexXxoS UT60 X-Flow Server Radiators help you to get one step closer!
Increase the performance of your system with the new Alphacool NexXxoS UT60 X-Flow Server Radiators.
X-Flow – Find the easy route
For the best possible cooling of your system, Alphacool relies on the X-Flow for the new NexXxoS server radiators. The flow runs from one side of the radiator to the other and directly uses all fins. Your Alphacool NexXxoS UT60 X-Flow immediately achieves the best possible cooling with optimized water circulation.
For the first time Alphacool has countersunk the screw plugs. This unique design allows you to stay flexible with the positioning of your Alphacool NexXxoS UT60 X-Flow Radiator. Mount your radiator the way you need it. Thanks to the multiple inlets and outlets, you have more options to create something unique and more importantly efficient.
The radiator of the new Alphacool NexXxoS series is also made of solid copper ensuring the radiators offer you the highest thermal conductivity for the best performance. Rely on the No. 1 in materials.
The new Alphacool NexXxoS UT60 X-Flow is available in different sizes and thicknesses. All radiators of this series are compatible with 2U server racks. Thanks to the special shape, installation is child's play, even with the larger radiators. Decide for yourself which size is perfect for your system and always choose the best quality.
Technical Data
Dimensions (L x W x H)124 x 40,5 x 60mm
Quantity of cooling channels9
Thickness49 - 69mm
Cooling channelsCopper
Fan threadM3
Connection6x G1/4"
SlatsCopper
Number of fans2
HousingSteel
Pressure tested0,8 bar
ManufacturerAlphacool
Fins per inch10
Fan size40mm
Alphacool ES TPV 8/5 - Tube - Black Matte 3,3m (10ft) Retailbox 330cm
€34.98 *
€5.48 *
22%
WAH Alphacool HDX - M.2 SSD M01 - 80mm - Schwarz EOL
Alphacool HDX - M.2 SSD M01 - 80mm - Black
€6.99 * €8.98 *
screws M3 x 35mm head (4 pieces)
€1.19 *
31%
hose PVC 8/5mm (1/4"ID) small bend radius Clear sold by the meter
€0.89 * €1.29 *
54%
hose PUR 8/6mm (1/4"ID) Black sold by the meter
€1.48 * €3.19 *
