Alphacool NexXxoS Monsta 180mm Triple radiator
  • 14215
  • 4250197142151
  • 3,709 kg
€205.98 *
Versatility is the essence of the new NexXxos series! The radiators are designed to be used with 120mm as well as 140mm fans and are available in different thicknesses. The choice of 30mm, 45mm and 60mm offers the perfect radiator for every purpose. Even mounting and installation of fans and radiator grills is easy and versatile with these radiators: The M3 threads are standard in the radiator sector and available in all lengths at an affordable price.
Info about the Monsta radiators:
The Monsta radiators, with a thickness of 80mm, are the first of their size on the market. Hence we were just as keen on finding out how they perform as the independent reviewers!
The tests show that it has significantly increased flow rates than thinner radiators. The cooling performance increased greatly with increased fan speed. Sounds normal, but this radiator shows a different performance profile than standard radiators: At 500rpm the Monsta is slightly better than its 60mm brother, but with increasing fan speed the difference increases: At 800rpm the Monsta already performs much better, and at 1200rpm a Monsta radiator is performing almost as well as a 60mm thick radiator with one fan more, at the same fan speed!
This is truly amazing, and all that at this affordable price!
Dimensions (L x W x H)585 x 182 x 85mm
Cooling channelsCopper
Fan threadM3
Number of fans3
SlatsCopper
Thickness69 - 100mm
HousingSteel
ManufacturerAlphacool
Pressure tested0,8 bar
Fins per inch10
Connection7x G1/4"
Fan size180mm
€6.99 *
