Alphacool Eiskoffer - measuring tool 90mm
ZSO Alphacool Eiskoffer - Messwerkzeug 90mm
  • 90360
  • 4250197136938
  • 0,011 kg
Measuring tool 90mm For measuring the distances between the fittings you want to connect.... more
Measuring tool 90mm
For measuring the distances between the fittings you want to connect. You can also connect the measuring tongues to each other or mount them on the bending plate to transfer measurement results.
manual
