Alphacool Eiskoffer - Flex-Bending Feeder
ZSO Alphacool Eiskoffer - Flex-Biegeanleger
  • 90350
  • 4250197136846
  • 0,016 kg
Flex bending feeder Investors for particularly large or freely adjustable radii. It is also... more
Flex bending feeder
Investors for particularly large or freely adjustable radii. It is also possible to change the radius in its course, i.e. to narrow or widen it.
The average radius is indicated by a marker.
Min. radius: 75 mm
Max. radius: 165 mm
All bending guides and stops are designed for pipe diameters of 12 or 13 mm and 16 mm. The required guide is always aligned downwards.
manual
€0.99 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Colonial Blue (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
56%
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Acid Purple (Paracord 550 Typ 3) 330cm EOL
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Acid Purple (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
ANZ Knickschutzfeder einzeln 16mm (100mm Lang) - black nickel PHT EOL
kink protection spring single 16mm (100mm long) - black nickel
Content 10 Zentimeter (€0.22 * / 1 Zentimeter)
€2.19 *
ANZ Knickschutzfeder einzeln 16mm (200mm Lang) PHT EOL
kink protection spring single 16mm (200mm long)
Content 20 Zentimeter (€0.30 * / 1 Zentimeter)
€5.99 *
