Spare parts
Top seller
85%
€1.98 * €12.98 *
Alphacool Eisblock Aurora mounting screws and springs M2x6mm
Content 10 Stück (€0.30 * / 1 Stück)
€2.98 *
Alphacool NexXxoS GPX accessory pack 3W/mk
Content 108 cm² (€0.04 * / 1 cm²)
€3.97 *
23%
Alphacool Aurora LED Flexible Light incl. Controller - RGB 30cm
Content 30 Zentimeter (€33.27 * / 100 Zentimeter)
€9.98 * €12.98 *
Close filters
WAGZ Alphacool NexXxoS GPX Beipack 3W/mk Alphacool NexXxoS GPX accessory pack 3W/mk
This Alphacool NexXxoS GPX accessory pack 3W/mk set is the perfect addition or replacement for the new Alphacool GPX series of graphics card coolers. Thanks to the 2 different sizes (30x30mm and 15x15mm) and the 3 different thicknesses...
€3.97 *
23%
LED Alphacool Aurora LED Flexible Light inkl. Controller - RGB 30cm EOL Alphacool Aurora LED Flexible Light incl. Controller - RGB 30cm
In addition to the Aurora LED rings, Alphacool also offers the Aurora Flexible Light. Like the Aurora LED rings RGB, this flexible light is available in RGB. The power supply is via a 4-pin Molex which can be easily connected to a fan...
€9.98 * €12.98 *
85%
LED Alphacool Aurora LED Flexible Light inkl. Controller - RGB 60cm EOL Alphacool Aurora LED Flexible Light incl. Controller - RGB 60cm
In addition to the Aurora LED rings, Alphacool also offers the Aurora Flexible Leight. Like the Aurora LED rings RGB, this flexible light is available in RGB. The power supply is via a 4-pin Molex which can be easily connected to a fan...
€1.98 * €12.98 *
WAGZ Alphacool Eisblock GPX LED Abdeckleiste mit Schrauben EOL Alphacool Eisblock GPX LED cover strip with screws
Replacement LED cover strip with screws for Alphacool Eisblock GPX
LED Alphacool Aurora LED Flexible Light - Digital RGB 20cm Alphacool Aurora LED Flexible Light - Digital RGB 20cm
Nothing remains hidden with the new Alphacool Aurora LED Flexible Light Digital RGB! Every corner of your case is illuminated quickly and easily. The Flexible Lights are available in sizes 5cm, 10cm, 20cm, 30cm and 60cm and therefore fit...
Content 20 Zentimeter (€69.90 * / 100 Zentimeter)
LED Alphacool Aurora LED Flexible Light - Digital RGB 30cm Alphacool Aurora LED Flexible Light - Digital RGB 30cm
Content 30 Zentimeter (€53.27 * / 100 Zentimeter)
WAGZ Alphacool Eisblock Aurora Montageschrauben und Federn M2x6mm Alphacool Eisblock Aurora mounting screws and springs M2x6mm
The article includes M2x6mm mounting screws with springs, for the Eisblock Aurora from Alphacool. Scope of delivery: 10x M2x6 mm screws with spring
€2.98 *
WAGZ Alphacool Eisblock GPX Aurora Abstandhalter M2 2,5mm Alphacool Eisblock GPX Aurora spacer M2 2.5mm
The article includes M2 spacers for the Eisblock Aurora from Alphacool. Scope of delivery: 10x M2 spacers
€2.98 *
WAGZ Alphacool GPU Terminal - Acetal Alphacool GPU Terminal - Acetal
This spare part is compatible with various Alphacool GPU coolers. It replaces the original component without adding any extra features or performance improvements. A detailed list of compatible and incompatible products can be found...
€20.98 *
WAGZ Alphacool Eisblock Aurora Montageschrauben für Original Backplate Alphacool Eisblock Aurora mounting screws for original backplate
The mounting kit is of interest to anyone who wants to use the original backplates from various graphics card manufacturers with the Eisblock Aurora cooler from Alphacool. However, it cannot be guaranteed that every backplate can be...
WAGZ Alphacool GPU Terminal flat straight - Acetal Alphacool GPU Terminal flat straight - Acetal
The classic orientation of the connection options on the Alphacool graphics card water coolers is vertical. If you prefer a horizontal orientation, you can now make your wish come true with the Alphacool GPU Terminal Flat. The terminal...
