Alphacool Eiswolf 2 AIO - 360mm RTX 4080 Founders Edition with Backplate
- Article no.: 14487
- EAN: 4250197144872
- Weight: 4,93 kg
Fullcover Waterblock?
Chrome-plated copper
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- Nvidia GeForce RTX 4080 Founders Edition, 16GB GDDR6X (900-1G136-2560-000)
- Nvidia GeForce RTX 4080 Super Founders Edition
| Technical data radiator | |
| Dimensions (L x W x H) | 395 x 124 x 30mm (+/- 3%) |
| Material cooling fins, chambers & channels | Copper |
| Material threads | Brass |
| G 1/4“ threads | 2 x for tubes (+ 1x Fillport G1/4“) |
| For fan size | 120 mm |
| Options for fan assembly | 3 x one-sided / 6 x both-sided |
| Technical data cooler and pump | |
| Dimensions (L x W x H) | 205,42 x 156,89 x 47,30 mm |
| Material cooler bottom | Chrome plated copper |
| Threads | 2 x G1/4“ |
| Pump type | DC-LT 2 |
| Pump speed | 2600 rpm (+/- 10%) |
| Head of delivery | 1 m |
| Maximum flow rate | 72 L/h |
| Voltage | 6-13.5V DC |
| Power consumption | 3.2W |
| MTBF | 50.000 h |
| Technical data liquid | |
| Color | clear |
| Ingredient 1 | Destilled water (CAS-number 7732-18-5) |
| Ingredient 2 | Glysantin (CAS-number 1017-21-1) |
| Working temperatures | -15 C° / +90 °C |
| Technical data quick fasteners | |
| Dimensions (L x D) | 95 x 27mm |
| Material | Nylon |
| For tube size | 12,7 / 7,6mm |
| Color | Black |
| Technical data fittings | |
| L x D straight fitting | 24 x 18mm |
| Quantity straight fittings | 2x |
| L x B x H 90° fitting | 35 x 27 x 17mm |
| Quantity 90° fittings | 2x |
| Material fittings | Brass |
| Technical data tube | |
| Length | 50cm |
| Material tube | TPV (EPDM/PP) |
| Color | Matt black |
| Tube size | 12,7 / 7,6mm |
| Hardness grade | 35 Shore-A to 50 Shore-D |
| Working temperature | -50 to +155 °C |
| Technical data fan | |
| Speed | 0 - 2500 RPM |
| Static pressure | 3,17 mm H2O |
| Air flow rate | 119,8 m³/h |
| Bearings | Sleeve bearing |
| Fan connector | 4-Pin PWM |
| Connection Digital aRGB | 3-Pin JST + 3-Pin 5V |
| Dimensions (L x W x H) | 120 x 120 x 25mm |
| Net weight | 187g |
| Hersteller: | Alphacool |
| Radiator dimensions: | 395 x 124 x 30mm |
| Radiator thickness: | 29 - 39mm |
| Radiator size: | 360mm |
| Hose dimensions: | 12,7/7,6mm |
| Base: | Nvidia GeForce; |
| Prefilled: | Yes |
