RGB cable
Top seller
€2.78 *
€0.99 * €4.89 *
€2.98 *
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
€2.98 *
86%
KAB Alphacool Y-Kabel RGBW 5pol auf 3x 5pol inkl. Stecker - Schwarz 60cm EOL
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 60cm
Content 60 Zentimeter (€1.65 * / 100 Zentimeter)
€0.99 * €6.89 *
51%
Alphacool Eis-Matrix connection cable to 4-pin RGB - 10cm
Content 10 Zentimeter (€9.80 * / 100 Zentimeter)
€0.98 * €1.98 *
€1.48 *
Close filters
1 From 2
KAB Alphacool Y-Kabel RGB 4pol auf 3x 4pol inkl. Stecker - Schwarz 60cm EOL Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
The new Alphacool Y-cable for 4-pin RGB connections allows up to three individual RGB components from the Alphacool RGB family to be combined into one input. This means that these three components can be connected to an RGB output from,...
€2.98 *
54%
KAB Alphacool RGB 4pol LED Adapterkabel für Mainboards - Schwarz 50cm EOL Alphacool RGB 4-pin LED adapter cable for motherboards - Black 50cm
This cable is a simple solution to connect motherboards from ASUS, Gigabyte or MSI to your RGB lighting. This way you can easily synchronize and control your RGB lighting via your motherboard's software! Also compatible with the...
Content 50 Zentimeter (€3.96 * / 100 Zentimeter)
€1.98 * €4.28 *
KAB Alphacool RGB 4pol LED Adapterkabel für Mainboards - Schwarz 100cm EOL Alphacool RGB 4-pin LED adapter cable for motherboards - Black 100cm
This cable is a simple solution to connect motherboards from ASUS, Gigabyte or MSI to your RGB lighting. This way you can easily synchronize and control your RGB lighting via your motherboard's software! Scope of delivery 1x...
€0.99 * €4.89 *
83%
KAB Alphacool Y-Kabel RGBW 5pol auf 3x 5pol inkl. Stecker - Schwarz 30cm EOL Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 30cm
The new Alphacool Y-cable for 5-pin RGBW connections allows up to three individual RGBW components from the Alphacool RGBW family to be combined into one input. This means that these three components can be connected to an RGBW output...
Content 30 Zentimeter (€3.30 * / 100 Zentimeter)
€0.99 * €5.89 *
86%
KAB Alphacool Y-Kabel RGBW 5pol auf 3x 5pol inkl. Stecker - Schwarz 60cm EOL Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 60cm
€0.99 * €6.89 *
KAB Alphacool Eis-Matrix Verbindungskabel - 10cm EOL Alphacool Ice Matrix connection cable - 10cm
Content 10 Zentimeter (€9.90 * / 100 Zentimeter)
€0.99 *
51%
KAB Alphacool Eis-Matrix Verbindungskabel auf 4pol RGB - 10cm EOL Alphacool Eis-Matrix connection cable to 4-pin RGB - 10cm
Finally here! The RGB connection cable for your Alphacool Eis-Matrix. The included connector serves as an adapter to connect your RGB products male or female to your Eis-Matrix. Technical details Cable length: 10cm Pin length connector: 4mm
€0.98 * €1.98 *
KAB Alphacool Digital RGB LED Y-Kabel 3-fach mit JST Stecker - Schwarz 30cm Alphacool Digital RGB LED Y-cable 3-way with JST connector - Black 30cm
The new Alphacool Y-cable for 3-way digital RGB connections allows you to combine up to three individual digital RGB components from the Alphacool digital RGB family into one input. This allows you to use ARGB solutions such as ASUS...
€6.99 *
KAB Alphacool Digital RGB LED Y-Kabel 3-fach mit JST Stecker - Schwarz 60cm Alphacool Digital RGB LED Y-cable 3-way with JST connector - black 60cm
KAB Alphacool Verbindungskabel 3Pin auf 3pol Digital RGB - 15cm Alphacool connection cable 3Pin to 3pin Digital RGB - 15cm
A simple aRGB adapter from 3-pin JST to 3-pin 5V. Compatible with all Alphacool aRGB products on the 3-pin JST connector and on the other end of the adapter to 3-pin 5V aRGB connectors, as used on many mainboards and by many aRGB...
€1.48 *
KAB Alphacool Eis-Matrix II - Adapter 5-Pin auf PWM + 5V Digital RGB (3pcs) je 20cm EOL Alphacool Eis-Matrix II - Adapter 5-Pin to PWM + 5V Digital RGB (3pcs) each 20cm
The Eis-Matrix II adapter offers the possibility of connecting additional Alphacool fans directly to the Eis-Matrix II controller. The Eis-Matrix II adapter has a 5-pin connector on one side that is connected directly to the controller....
Content 20 Zentimeter (€22.35 * / 100 Zentimeter)
€4.47 *
KAB Alphacool Verlängerung JST aRGB 3-Pin auf 3-Pin 15cm Alphacool extension JST aRGB 3-pin to 3-pin 15cm
A simple aRGB extension from JST 3-pin male to 3-pin female (5V). Compatible with all Alphacool aRGB products. Technical details Length 15cm Connections JST 3-pin to 3-pin Voltage 5V Material Plastic, sleeved Color black
Content 15 Zentimeter (€8.60 * / 100 Zentimeter)
€1.29 *
KAB Alphacool Verlängerung JST aRGB 3-Pin auf 3-Pin 30cm Alphacool extension JST aRGB 3-pin to 3-pin 30cm
A simple aRGB extension from JST 3-pin male to 3-pin female (5V). Compatible with all Alphacool aRGB products. Technical details Length 30cm Connections JST 3-pin to 3-pin Voltage 5V Material Plastic, sleeved Color black
€1.48 *
KAB Alphacool Verlängerung JST aRGB 3-Pin auf 3-Pin 60cm Alphacool extension JST aRGB 3-pin to 3-pin 60cm
A simple aRGB extension from JST 3-pin male to 3-pin female (5V). Compatible with all Alphacool aRGB products. Technical details Length 60cm Connections JST 3-pin to 3-pin Voltage 5V Material Plastic, sleeved Color black
€1.68 *
KAB Alphacool Verlängerung aRGB 3-Pin auf 3-Pin 15cm Alphacool extension aRGB 3-pin to 3-pin 15cm
A basic aRGB extension from 3-pin to 3-pin (5V). Compatible with all Alphacool aRGB products and most motherboards and aRGB controllers. Technical details Length 15cm Connections 3-pin to 3-pin Voltage 5V Material Plastic, sleeved Color...
€2.58 *
KAB Alphacool Verlängerung aRGB 3-Pin auf 3-Pin 30cm Alphacool extension aRGB 3-pin to 3-pin 30cm
A basic aRGB extension from 3-pin to 3-pin (5V). Compatible with all Alphacool aRGB products and most motherboards and aRGB controllers. Technical details Length 30cm Connections 3-pin to 3-pin Voltage 5V Material Plastic, sleeved Color...
€2.78 *
KAB Alphacool Verlängerung aRGB 3-Pin auf 3-Pin 60cm Alphacool extension aRGB 3-pin to 3-pin 60cm
A basic aRGB extension from 3-pin to 3-pin (5V). Compatible with all Alphacool aRGB products and most motherboards and aRGB controllers. Technical details Length 60cm Connections 3-pin to 3-pin Voltage 5V Material Plastic, sleeved Color...
€2.98 *
KAB Alphacool Y-Splitter aRGB 3-Pin auf 2x 3-Pin 15cm Alphacool y-splitter aRGB 3-pin to 2x 3-pin 15cm
A high quality sleeved aRGB 3-pin to 2x 3-pin Y-splitter cable. Compatible with all Alphacool aRGB products as well as most motherboards and aRGB controllers. This Y-splitter can be used to combine multiple aRGB elements. Technical...
€3.47 *
1 From 2
