Other cables
Top seller
20%
KAB Alphacool Apex PCI-e 4.0 Riser Kabel - 20cm
Alphacool Apex PCI-e 4.0 Riser cable - 20cm
Content 20 Zentimeter (€299.90 * / 100 Zentimeter)
€59.98 * €74.98 *
KAB Alphacool Mini USB auf Mainboard USB 5-Pin 40cm EOL
Alphacool Mini USB to Mainboard USB 5-Pin 40cm
Content 40 Zentimeter (€7.45 * / 100 Zentimeter)
€2.98 *
Alphacool 4-Pin Molex to Lumberg 10cm
Content 10 Zentimeter (€44.80 * / 100 Zentimeter)
€4.48 *
Close filters
ZK Delock MiniPCIe Konverter mSATA full size - 7 Pin EOL Delock MiniPCIe converter mSATA full size - 7 pin
This module by Delock converts the mSATA interface into a SATA 7 pin interface. This allows you to connect a SATA SSD / HDD to the module. The module is suitable for a full size slot. The SATA connection can be accessed from both sides...
PUZ Alphacool Core ATX 24-Pin Überbrückungsstecker Alphacool Core ATX 24-pin jumper plug
The Alphacool Core ATX jumper plug is a simple but highly effective tool. Once the water cooling system is assembled, the system must be filled. To do this, the pump needs power from the power supply; the system itself should remain...
€3.98 *
20%
KAB Alphacool Apex PCI-e 4.0 Riser Kabel - 20cm Alphacool Apex PCI-e 4.0 Riser cable - 20cm
The 20cm long Alphacool Apex PCI-e 4.0 riser cable enables flexible and individual positioning of the PCI-Express x16 slot inside or outside the case. Flexible application! Should the graphics card be changed regularly, the riser cable...
€59.98 * €74.98 *
KAB Alphacool Mini USB auf Mainboard USB 5-Pin 40cm EOL Alphacool Mini USB to Mainboard USB 5-Pin 40cm
High quality Mini USB to motherboard USB 5-pin cable with 40cm length for connecting electronic components. For example for mounting USB devices inside the case like fans/RGB controllers. Technical data Length 40cm Connections Mini USB...
€2.98 *
KAB Alphacool 4-Pin Molex auf Lumberg 10cm EOL Alphacool 4-Pin Molex to Lumberg 10cm
Sleeved 4-pin Molex cable to Lumberg with 10cm length and 12V voltage for connecting power supplies. Technical data Length 10cm Voltage 12V Connections 1x 4-Pin Molex to 1x Lumberg Weight 8g Color black
€4.48 *
KAB Alphacool Dual 24-Pin Netzteil Starterkabel (2x24-Pin auf 1x24-Pin) Alphacool Dual 24-pin power supply starter cable (2x24-pin to 1x24-pin)
Alphacool's Dual 24-pin Power Supply Starter Cable allows for the parallel starting of two power supplies through the motherboard. This allows for an additional power supply with its own power circuit to be added to the system. This is...
