Fan cable
Top seller
€2.98 *
€1.98 *
€2.48 *
€2.58 *
€2.68 *
€3.47 *
€2.58 *
€2.78 *
Close filters
1 From 3
LK Adapter 3Pin (12V) auf 4Pin Molex (12V) PHT EOL Adapter 3Pin (12V) to 4Pin Molex (12V)
. Product description For connecting the 3-pin fan connector, e.g. on the mainboard, to a power supply connector (4-pin Molex), among other things to obtain an additional power connection.
€1.79 *
LK Alphacool Lüfterkabel 4-Pin auf 4-Pin Verlängerung 15cm Alphacool fan cable 4-pin to 4-pin extension PWM 15cm
An extension cable for 4-pin PWM fans. Available in various lengths. Sleeving provides additional protection, stability and increased lifetime. Technical details Length 15cm Connections 4-pin to 4-pin Material Plastic, sleeved Color black
€1.98 *
LK Alphacool Lüfterkabel 4-Pin auf 4-Pin Verlängerung 30cm Alphacool fan cable 4-pin to 4-pin extension PWM 30cm
An extension cable for 4-pin PWM fans. Available in various lengths. Sleeving provides additional protection, stability and increased lifetime. Technical details Length 30cm Connections 4-pin to 4-pin Material Plastic, sleeved Color black
€2.28 *
LK Alphacool Lüfterkabel 4-Pin auf 4-Pin Verlängerung 60cm Alphacool fan cable 4-pin to 4-pin extension PWM 60cm
An extension cable for 4-pin PWM fans. Available in various lengths. Sleeving provides additional protection, stability and increased lifetime. Technical details Length 60cm Connections 4-pin to 4-pin Material Plastic, sleeved Color black
€2.68 *
LK Alphacool Y-Splitter 4-Pin auf 2x 4-Pin PWM 15cm Alphacool y-splitter 4-Pin to 2x 4-Pin PWM 15cm
Sleeved 4-Pin auf 2x 4-Pin Y-splitter distribution cable. Distributes power supply and PWM singal to multiple fan connectors. Sleeving provides additional protection, stability and longer lifetime. Technical details Length 15cm...
€2.48 *
LK Alphacool Y-Splitter 4-Pin auf 2x 4-Pin PWM 30cm Alphacool y-splitter 4-Pin to 2x 4-Pin PWM 30cm
Sleeved 4-Pin auf 2x 4-Pin Y-splitter distribution cable. Distributes power supply and PWM singal to multiple fan connectors. Sleeving provides additional protection, stability and longer lifetime. Technical details Length 30cm...
€2.68 *
LK Alphacool Y-Splitter 4-Pin auf 2x 4-Pin PWM 60cm Alphacool y-splitter 4-Pin to 2x 4-Pin PWM 60cm
Sleeved 4-Pin auf 2x 4-Pin Y-splitter distribution cable. Distributes power supply and PWM singal to multiple fan connectors. Sleeving provides additional protection, stability and longer lifetime. Technical details Length 60cm...
€3.47 *
LK Alphacool Y-Splitter 4-Pin auf 3x 4-Pin PWM 15cm Alphacool y-splitter 4-Pin to 3x 4-Pin PWM 15cm
Sleeved 4-Pin auf 3x 4-Pin Y-splitter distribution cable. Distributes power supply and PWM singal to multiple fan connectors. Sleeving provides additional protection, stability and longer lifetime. Technical details Length 15cm...
€2.78 *
LK Alphacool Y-Splitter 4-Pin auf 3x 4-Pin PWM 30cm Alphacool y-splitter 4-Pin to 3x 4-Pin PWM 30cm
Alphacool's 4-pin to 4x 4-pin Y-splitter cable is a high-quality solution to easily connect and control multiple PWM fans from the motherboard without the need for a separate fan control HUB. This cable is ideal for expanding the limited...
€3.47 *
LK Alphacool Y-Splitter 4-Pin auf 3x 4-Pin PWM 60cm Alphacool y-splitter 4-Pin to 3x 4-Pin PWM 60cm
€4.38 *
LK Alphacool Y-Splitter 4-Pin auf 4x 4-Pin PWM 15cm Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 15cm
€3.47 *
LK Alphacool Y-Splitter 4-Pin auf 4x 4-Pin PWM 30cm Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 30cm
LK Alphacool Y-Splitter 4-Pin auf 4x 4-Pin PWM 60cm Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 60cm
Alphacool's 4-pin to 4x 4-pin Y-splitter cable is a high-quality solution to easily connect and control multiple PWM fans from the motherboard without the need for a separate fan control HUB.This cable is ideal for expanding the limited...
€5.28 *
LK Alphacool Lüfterkabel 3-Pin auf 3-Pin Verlängerung 15cm Alphacool fan cable 3-Pin to 3-Pin extension PWM 15cm
An extension cable for 3-pin fans. Available in various lengths. Sleeving provides additional protection, stability and increased lifetime. Technical details Length 15cm Connections 3-pin to 3-pin Material Plastic, sleeved Color black
€1.98 *
LK Alphacool Lüfterkabel 3-Pin auf 3-Pin Verlängerung 30cm Alphacool fan cable 3-Pin to 3-Pin extension PWM 30cm
An extension cable for 3-pin fans. Available in various lengths. Sleeving provides additional protection, stability and increased lifetime. Technical details Length 30cm Connections 3-pin to 3-pin Material Plastic, sleeved Color black
€2.28 *
LK Alphacool Lüfterkabel 3-Pin auf 3-Pin Verlängerung 60cm Alphacool fan cable 3-Pin to 3-Pin extension PWM 60cm
An extension cable for 3-pin fans. Available in various lengths. Sleeving provides additional protection, stability and increased lifetime. Technical details Length 60cm Connections 3-pin to 3-pin Material Plastic, sleeved Color black
€2.48 *
LK Alphacool Y-Splitter 3-Pin auf 2x 3-Pin 15cm Alphacool y-splitter 3-Pin to 2x 3-Pin 15cm
Sleeved 3-pin to 2x 3-pin Y-splitter distribution cable. Distributes power supply and RPM singal to multiple fan connectors. Sleeving provides additional protection, stability and longer lifetime. Technical details Length 15cm...
€2.28 *
LK Alphacool Y-Splitter 3-Pin auf 2x 3-Pin 30cm Alphacool y-splitter 3-Pin to 2x 3-Pin 30cm
Sleeved 3-pin to 2x 3-pin Y-splitter distribution cable. Distributes power supply and RPM singal to multiple fan connectors. Sleeving provides additional protection, stability and longer lifetime. Technical details Length 30cm...
Content 30 Zentimeter (€8.27 * / 100 Zentimeter)
€2.48 *
1 From 3
