B-stock Alphacool Eisrohr 16/13mm Acryl (PMMA) HardTube Satin 80cm - 4pcs set (320cm)
- Article no.: 1024048
- EAN: 4049469324520
- Weight: 0,383 kg
This is a B-stock item.
The hard tubes are unused. Minor coating imperfections are present in a few areas; however, these do not affect tightness or functionality.
For further information, please refer to item 1012480.
| Hersteller: | Alphacool |
| Outer diameter: | 16mm (5/8") |
| Color: | Transparent |
| Operating temperature: | -20°C to +60°C |
| Inner diameter: | 13mm (1/2") |
| Length: | 80cm |
| Material: | Acryl; |
| Maximum operating pressure: | 4 bar (at 20°C) |
| UV ink: | Not UV-active |
