Alphacool Powerbutton with push-button 19mm white lighting - deep black
  • 17437
  • 4250197174374
  • 0,1 kg
€32.98 *
The world-famous water cooling manufacturer Alphacool offers a simple solution with the power... more
The world-famous water cooling manufacturer Alphacool offers a simple solution with the power button to start your PC quickly and easily. Most computers are placed under or on the side of the desk. In this position, the start button is usually difficult to reach. In the area of modding, start buttons are also usually positioned differently than usual.
With the Alphacool Powerbutton, you can finally position your start button the way you want it thanks to the 2 m long cable. Whether to the left or right of your keyboard or in front of your monitor, enjoy the freedom you get.
When your computer starts, the power button lights up to give you feedback on the status of your PC.
The cable pre-mounted on the power button is connected directly to your mainboard. At the end of the cable is a Y-splitter to which the start button of the case is connected. This means you can start and turn off your computer either via the power button or as usual via the case.
  • Dimensions
    Diameter base: 50mm
    Tower diameter: 45mm
    Height: 49mm
    Hole for button: 19mm
  • Material: aluminum
  • Colour: Deep Black
  • Cable length: 2m
  • LED color: white
Scope of delivery
  • 1x Alphacool power button with button 19mm red illuminated - Deep Black
  • User manual
