B-stock Alphacool NexXxoS UT60 Full Copper 420mm radiator
RAD B-Ware Alphacool NexXxoS UT60 Full Copper 420mm Radiator
  • 1016961
  • 4049469253509
  • 2,374 kg
€79.98 * €122.97 * (34.96% Saved)
This is a B-stock item. The radiator has two slight dents on the upper cooling channels... more
The radiator has two slight dents on the upper cooling channels but is leak-tight and fully functional.
For further information, please refer to item 1022851.
Gebrauchte Ware
Fins per inch: 10
Housing: Steel;
Cooling channels: Copper
Slats: Copper
Fan thread: M3
Fan size: 140mm;
Dimensions (L x W x H): 466 x 144 x 60mm
Connection: 6x G1/4"
Number of fans: 3;
Thickness: 69 - 100mm
Pressure tested: 2 bar
Color: Black
