B-stock Alphacool Eisblock Aurora Acryl GPX-A eon RX 6900XT Toxic with backplate
- Article no.: 1024081
- EAN: 4049469324858
- Weight: 1,385 kg
This is a B-stock item.
This item is a returned product that has already been opened. Minor signs of use may be present. The item is in like-new condition, complete, and fully functional.
Additional information (original item: 1022353):
More performance!
During the development of the Eisblock Aurora Acryl GPX graphics card water cooler, emphasis was naturally placed on increasing performance. First, the cooler was brought closer to the individual components by reducing the thickness of the heat conducting pads. Next, the nickel-plated copper block was also made thinner. Step 3 involves the constant optimisation of the water flow within the cooler. The result: All important components such as voltage converters and RAM are cooled much better and more effectively by the water and the cooling performance increases significantly.
Brilliant design!
Copper or aluminium?
Alphacool only uses copper in its water coolers. In the case of the Eisblock Aurora Acryl GPX, the copper is nickel-plated. Compared to the previous models, however, Alphacool has once again improved the type of nickel plating, which has significantly increased the acid resistance. This should prevent the nickel plating from flaking off. Why does Alphacool use copper instead of aluminium? Copper has almost twice the thermal conductivity of aluminium and is therefore clearly the better material for water cooling.
Other special features
- Sapphire Nitro+ Radeon RX 6900 XT SE, 16GB GDDR6 (11308-03-20G)
- Sapphire Toxic Radeon RX 6900 XT Air Cooled, 16GB GDDR6 (11308-11-20G)
- Sapphire Toxic Radeon RX 6900 XT Extreme Edition, 16GB GDDR6 (11308-08-20G)
- Sapphire Toxic Radeon RX 6900 XT Limited Edition, 16GB GDDR6 (11308-06-20G)
- Sapphire Nitro+ Radeon RX 6950 XT, 16GB GDDR6 (11317-02-20G)
- Sapphire Radeon RX 6950 XT Nitro+ Pure (11317-04-20G)
- Sapphire Toxic Radeon RX 6950 XT Limited Edition, 16GB GDDR6 (11317-01-20G)
| Technical data cooler | |
| L x W x H | 259 x 144,50 x 25,4mm |
| Material cooler | Nickle-plated copper |
| Threads | 4 x G1/4 |
| Thickness cooling fins | 0,6 mm |
| L x W x H | 259 x 120 x 6mm |
| Material | aluminium |
| Color | black |
| Hersteller: | Alphacool |
| Cooler type: | Complete cooler |
| Material base plate: | Copper; |
| Material Lid: | Acrylic; |
| SLI compatible: | Yes |
| Dimensions: | 259 x 144,50 x 25,4mm |
| Connection: | 4x G1/4" |
| Hardware manufacturers: | AMD |
| Hardware model: | Radeon RX 6900XT; |
| Notice: | Compatible up to 16/13mm straight; Compatible up to 19/13mm angled; |
