Alphacool Apex Skeleton Carbon Case
  • 14593
  • 4250197145930
  • 13,414 kg
€649.98 *
Delivery date: in 5 - 6 weeks
€37.98*
13439 Alphacool Core Geforce RTX 4080 Reference Design with Backplate
€69.98*
13446 Alphacool Core 1 Aurora Black
€125.98*
13823 Alphacool Apex Stealth Metal Power fan 3000rpm matte black (120x120x25mm)
€21.98*
Unlimited freedom with the Alphacool Apex Skeleton. Made from carbon rods and CNC-milled... more
Unlimited freedom with the Alphacool Apex Skeleton. Made from carbon rods and CNC-milled aluminum connectors, this case was specially developed to meet the requirements of water cooling systems. In this version, it is delivered without a distro plate, pump and vertical GPU holder. This provides additional scope for creativity. The Skeleton can still be completely dismantled and can be adapted to suit your personal requirements.
A new level of creativity
The Alphacool Apex Skeleton Carbon case is characterized by a design in which all components are screw-mounted, which allows for extensive modifiability. Equipped with three radiator mounts, two for 360mm and one for 120mm, this case offers ideal conditions for high-performance cooling systems. The mainboard tray including cable box can also be positioned flexibly. The smoked glass side panel is another feature that opens up additional design options, as is the freely selectable positioning of the front panel. All in all, the skeleton case allows a great deal of freedom and creative ideas.
Apex Design
The Apex product line from Alphacool represents the highest level of perfection. First-class materials and innovative technologies guarantee a unique premium product. Consisting of real carbon and modular, CNC-milled aluminum connectors, the Apex Skeleton case offers limitless creativity with a unique look. Inside each Skeleton case resides a truly unique creation waiting to be unleashed.
Dimensions (L x W x H)607.50 x 259.80 x 573.00 mm
Weight11kg
MaterialCarbon, aluminum, smoked glass
Mainboard supportATX, mATX, EATX, ITX
GPU bracketHorizontal: 2+ Slot
PCIe slots7
Drive mount1x 2,5" SSD
Power supply bracketATX Standard
Radiator front/top support120, 240, 360mm
Radiator rear support120mm
Frontpanel USB2x 3.0 Type A
Frontpanel Audio1x audio output | 1x microphone input
PCI Express Riser4.0 x16
Colorcarbon, black
Awards & Videos
S16 Alphacool HardTube 16/11mm Borosilikatglas 60cm
Alphacool HardTube 16/11mm borosilicate glass 60cm
Content 60 Zentimeter (€23.30 * / 100 Zentimeter)
