B-stock Alphacool Core RX 7900XTX/XT Taichi - Phantom with backplate
WAK B-Ware Alphacool Core RX 7900XTX/XT Taichi - Phantom mit Backplate
  • 1024595
  • 4049469329990
  • 2,545 kg
€119.98 * €199.98 * (40% Saved)
This is a B-stock item. This item is a returned product that has already been opened.... more
This item is a returned product that has already been opened. Minor signs of use may be present. The thermal pads and thermal paste are missing from the mounting material; otherwise, the item is fully functional.
For further information, please refer to item 1023677.
Gebrauchte Ware
Cooler type: Complete cooler
Material base plate: Copper;
Material Lid: Acrylic;
Dimensions: 276 x 143,90 x 31,93mm
Connection: 4x G1/4"
Hardware manufacturers: AMD
Hardware model: Radeon RX 7900XT;Radeon RX 7900XTX;
