Alphacool Ice Layer Thermal Pad - 17W/mK 120x20x1.5mm - 2 pieces
  • 12470
  • 4250197124706
  • 0,048 kg
€139.98 *
Content: 48 cm² (€2.92 * / 1 cm²)
The "Alphacool ice layer" offers all the advantages and typical properties of a thermal pad: self-adhesive (both sides), elastic, adaptable and much more! The area of application is just as versatile, whether for RAM and mainboard coolers or graphics card and CPU coolers, wherever the circuit board meets the heat sink, the Alphacool ice layer is a good choice.
Fastening: Slightly adhesive
Thickness: 1,5mm
Surface dimensions: 120 x 20mm
Thermal conductivity: 17W/mk
WÄM Alphacool Wärmeleitklebepad doppelseitig 100x100x0,5mm EOL
Alphacool thermal adhesive pad double-sided 100x100x0.5mm
Content 100 cm² (€0.04 * / 1 cm²)
€3.97 *
€0.98 *
€1.19 *
