Alphacool Eiswolf 2 AIO - 360mm RTX 3090 TI FTW3 with backplate
- Article no.: 14478
- EAN: 4250197144780
- Weight: 5,18 kg
The Alphacool Eiswolf 2 is the first full cover GPU AIO waterblock from Alphacool. It is based on the Alphacool Eisblock Aurora GPX water block, a pump unit and a 360mm NexXxoS ST30 full copper radiator. The latter is equipped with the Alphacool Aurora Rise Digital RGB fans.
Fullcover Waterblock?
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- EVGA GeForce RTX 3090 Ti FTW3 Black Gaming (24G-P5-4981-KR)
- EVGA GeForce RTX 3090 Ti FTW3 Gaming (24G-P5-4983-KR)
- EVGA GeForce RTX 3090 Ti FTW3 Ultra Gaming (24G-P5-4985-KR)
- EVGA GeForce RTX 3090 Ti FTW3 Ultra Hybrid Gaming (24G-P5-4988-KR)
- EVGA GeForce RTX 3090 Ti FTW3 Ultra Hydro Copper Gaming (24G-P5-4989-KR)
Technical data radiator | |
L x W x H | 395 x 124 x 30mm (+/- 3%) |
Material threads | Brass |
For fan size | 120 mm |
Possible fan assembly | 3 x one-sided / 6 x both-sided |
L x W x H | 289,46 x 159,85 x 46mm |
Threads | 2 x G1/4“ |
Pump type | DC-LT 2 |
Head of delivery | 1 m |
Maximum flow rate | 72 L/h |
Voltage | 6-13.5V DC |
Power consumption | 3.2W |
MTBF | 50.000 h |
Technical data liquid | |
Color | clear |
L x D | 95 x 27mm |
Material | Nylon |
Color | Black |
Technical data fittings | |
Quantity 90° fittings | 2x |
Material fittings | Brass |
Technical data tube | |
Length | 50cm |
Color | Matt black |
Tube size | 12,7 / 7,6mm |
Technical data fan | |
Speed | 0 - 2500 RPM |
Air flow rate | 119,8 m³/h |
Bearings | Sleeve bearing |
Fan connector | 4-Pin PWM |
Dimensions | 120 x 120 x 25mm |
Net weight | 187g |
Radiator dimensions: | 395 x 124 x 30mm |
Radiator thickness: | 29 - 39mm |
Radiator size: | 360mm |
Hose dimensions: | 12,7/7,6mm |
Base: | Nvidia GeForce; |
Prefilled: | Yes |
