Water filter
Close filters
WZS Alphacool Eiszapfen Acryl/Acetal Inline Filter G1/4 IG Alphacool Eiszapfen Acryl/Acetal Inline filter G1/4 inner thread
The Alphacool Eiszapfen acrylic acetal inline filter protects your water circuit from unwanted particles. The hole thickness of the filter screen is 0.5 mm. This catches all particles that could potentially damage the pump. The filter...
WZS Alphacool ES Big Inline Partikelfilter 2x G1/4" IG Alphacool ES Big Inline particle filter 2x G1/4" IG
The ES Big Inline 2x G1/4" IT particle filter from Alphacool's Enterprise Solutions series can be integrated into a cooling loop and enables filtering of harmful particles that can find its way into the system. Thanks to the Big Inline...
WZS Alphacool ES Inline Partikelfilter 2x G1/4" IG Alphacool ES Inline particle filter 2x G1/4" IT
The Alphacool inline particle filter from the Enterprise Solutions product range catches dirt particles from the cooling loop. This protects sensitive components such as pumps or the fine cooling fins. Flexible installation The ES Inline...
